It just died!
Bakersfield
has anybody had this happen? driving to LA yesterday just before the grapevine my 91 fj80 out of the blue just died for no apparent reason. Ive since had some time to try to find the problem to no avail. no spark any suggestions?:bang:
Pull your ECU fuse for a minute, reinstall and try again.
Starter been ok or clicking? All your idiot lights light up as she died? Could be that your starter seized.
Sounds like a known issue. Not positive, but EFI fuse and wire that feeds it would be my 90% guess as to that known problem. Results in crank and no start as you have. Search, grasshopper....
DougM
Heh. Yeah, I think it's a wire that's not as thick as it should be on the EFI - forget which side, ground or power - and it either shortens the life of the EFI relay or similar. Clean up the EFI relay contacts as a first order of business, then buy another one as the second order and replace the wire as a third if still no love.
DougM
Check the cap and rotor if it is ok then check the coil wire with a ohm meter. If the coil wire is good then check the ignition coil with an ohm meter. If that is good then try another igniter (mounted to fender well on yours). If none of those work then it could be the pickups in the distributor, wiring problem or ECU. My guess is the igniter aka Ignition module.
OK I changed the EFI relay no change, depowered the ECU no change, changed the ingnition modual no change(and there real proud of those things cheapest I found was 189.00 at pep boys all the way to 459.00 at kragen) and still no spark:clap:
I had mine die on I-20. Turned out (according to shop that fixed it) that one of the O2 sensors shorted out, blowing my ignition fuse.
Just a thought, I am not a mechanic.
Ok I think ive found the problem :hhmm: . in the distributer their are 2 magnetic pick ups both of which should read approx. 256.0 ohms in mine 1 of them is reading 0 when the other is reading normal . Now heres the million dollar question does anybody know where I can buy just the pick ups or do you have to buy the whole distrubuter?
Here is a tip.
Get electronic parts for plug and play troubleshooting from a yard.
If something did not fix a problem you usually cannot return a new electronic part and they are expensive. A ignitor from a yard is cheap compared to a new one. A distrubutor would be $850 or so from mr T but I am guessing under $100 from a yard.
Did you check the GROUND side of the EFI relay circuit? I have not done a search, but if memory serves it may be the ground side that needs a new thicker wire which would explain why you show power to the EFI relay is OK.
DougM
It's typically the +12 side of the EFI circuit inside the fusebox that needs replacing (from the EFI fuse to the load side of the relay), but if he really has a shorted pick up coil in the dissy, then there will be no spark as there will be no signal to the ECU.
I'm making the assumption that the OP has followed my EFI troubleshooting procedure and is competant with a meter. He should also have a copy of the FSM as all information is in there.
