It Drips Everywhere
Southern WI
My 92 80 has a 3FE with 295 k on it. Its hard to tell where the leaks are coming from since the entire engine is coated in a thick film of oil, antifreeze, and power steering fluid.
I've just rebuilt the PS pump, since its high and in front, and fabricated a new PS return line since it cracked. So the PS is now leak free.
I've recently noticed a few antifreeze drips on the crankshaft pulley and its belts, so i think the water pump is on the fritz. I plan on replacing that soon, and therein lies my delema.
I think the valve cover, pushrod cover, and oil pan cover are all slowly oozing, and from below, it looks like i have a head gasket leak as well, but its hard to tell since everything has oil on it.
When i replace the water pump, i think i'll be able to tell if the head is leaking. Should i fix it then, or just keep driving it and fix all the easier leaks. It only drips three or four drips at the end of each drive, and has been that way since 2000.
How common are head gasket leaks on a 3FE with 295k, and what is the life expectency of the engine. It runs sound, starts great, the fuel economy is average for its class. If i do the head will it die the week after, and if i don't do the head will it run to a million driping the whole way. Is it worth the time to just do it, and what should i expect to pay for the gaskets from cdan, a couple hundred or a thousand.
Drip, drip drip.
I say let her drip. :beer:
I epoxied the floor in my garage, kept a roll of paper towels handy, and kept topping everything off.
Are you talking about the head gasket, or the Valve Cover Gasket....? If the Head Gasket failed you would have more problems than just some dripping of oil...
Not a bad idea to do it all when you are in there, but check your coolant bypass hose (on thermostat outlet) for your source of coolant leak...I have seen a few of these cause the coolant leak you are describing before they completely fail.
Yo Pig...."...they all did that" . . .you mean the drip-drip ?
yea, I think they do....a bad habit they picked up from Land Rovers :-)
clean the thing up to start with... or are you afraid the leaks will get bigger without the coating? :)
Think i fixed my coolant leak, it was the cap on my flushing tee. But all day i watched my temp gauge and it seemed like it was moving around more than it should. The needle covered the upper line of the gauge, not the top H line, but the one 2/3 up. Now and then it would dip, sometimes pretty quickly towards the middle where i thought it should be. Where is the needle supposed to ride? Oh yeah, the themostat is only 2 years old.
So when the head goes, it goes huh? I don't think I'm going to touch it then, I'll just fix the valve cover gasket which has a major case of leakalightus, then clean everything up and inspect more. The mess on the head is probably from that.
The oil is great though, it keeps the salt from mangling everything. And i think i even see the virgin Mary in my oil stained concrete garage floor. Tours anyone!:idea:
Think i fixed my coolant leak, it was the cap on my flushing tee. But all day i watched my temp gauge...Where is the needle supposed to ride?
"Where is the needle supposed to ride?"
Yeah, I've been wondering the same - what is the normal position of the temp gauge needle on the 3FE at normal operating temp?
I replaced the self-destructed thermostat (it was old) and radiator cap with new from cdan and when fully warmed up, the temp needle hovers nervously over the half-way mark. On the plus side, it's quieter and appears to run better now.
"And i think i even see the virgin Mary in my oil stained concrete garage floor."
That's kwl. Let us know if it changes to Elvis.
Thanks for the post.
Head gaskets are rare on the 3FE.
Valve cover gasket and grommets, side cover gasket, oil pan gasket should all be purchased from Toyota and are somewhat easy to do and are a common source of oil leaks and vacuum leaks on a vehicle of this age.
Make sure you have ammased the correct parts for the water pump replacement as the entire front of the motor must come apart. Great time to replace the fan clutch, both belt idler pullies, clean the radiator from the inside, etc.
The FSM is good for this procedure and here is a MUD post about it for your enjoyment:
https://forum.ih8mud.com/80-series-tech/239380-live-help-wanted-water-pump-remove.html
Replaced the valve cover gasket on my 3FE about a month ago, what a huge difference it is making. Oil dripage is down 75-80%, and the image of the virgin Mary is slowly fading from my garage floor. After getting everything off and out of the way, i could see where it was leaking in the rear pretty bad. The whole procedure was pretty easy, had to lift the front of the cover first, then kinda rotate clockwise 90 degrees to get the rear out. Putting the cover back on without the new gasket falling off was tricky and took a few tries.
My next project is replacing the lifter cover gasket. Besides the air intake and any vac lines in the way, I plan on pulling the distributor and plug lines so I can get in there better and clean it up. Do I have to remove the PS pump and bracket to get at the front 2 bolts? Does anyone have any helpful hints?
I thought i could cut the heads off a few bolts, partially thread those in, and use them to hold/align the gasket and cover, the same technique used to hold eveything in place when doing the front end rebuild. I'll be flying solo on this one, so any suggestions would be great.
