Found it. 3FE Yahoo Groups message # 71649. Copied below:
So after 2 weeks of waiting for parts and decent weather, the water pump,
hoses, belts, idler pullies, and a host of other parts are all put back
together. Around midnight last night I took another final look at things and
went back over most of the bolts. I checked the parts tray and there was
nothing left over so I filled up the radiator fired that motha up.
After 2 weeks of sitting in pieces she fired on the first rotation of the
crank. I love that. Got underneath and waited for leaks, but alas, there
were none. Put the steering damper and belly pan back on. She purrs like a
kitten. Very quiet now.
What a PITA ordeal for a 3FE motor. Below is a list of items that need to be
removed in order. I'm assuming you drained the coolant first.
Steering damper mount (let it dangle from the relay rod), belly pan,
battery, battery tray, right side wheel well skirts, carb cooling fan
plenum, smog pump hoses, smog pump (York), alternator adjuster, upper
radiator hose, fan, fan shroud, belts, PS idler pulley bracket, AC idler
pulley bracket, 3 piece lower radiator hose, and all 3 studs that secure the
water pump to the block need to be removed. Then you can pull and replace
the water pump.
Add several hours for cleaning parts, soaking 16 year old bolts in
penetrating oil, running cleaned bolts through bolt holes with moly grease,
and...well you get the picture. Not a trailside repair.
Hooray.
