Isuzu Trooper windshield swap??
Some but not all light duty and HD stuff swaps. If it has the vented "wide" rotor it's the same, if it has the narrow non-vented rotor, different caliper.
On the note of calipers:
Speaking of 7x series in general, some inner axle shafts can be the same, not always. For example 9.5" axles (which were never on light duty stuff) have a wider diffs and shorter short shafts than an 8" setup. Steering/Suspension stuff is beefier on the HD. While you're right the Prado 7x holistically shares more parts with the HD 7x, it's overall robustness of parts is better compared to the Hilux, Surf, PU, etc as the diffs, steering, brakes, engine, trans are the factors imo more so than the actual overlap of part numbers.
I was just comparing 1990+ LJ7x to HZJ7x with those part numbers.
As far as robustness goes, I agree with you regarding the engine, suspension and non floating 8" rear axle (that said, the 1990+ LJ7x suspension and axle housings are UNIQUE and not from a Hilux). Most everything else I consider the same as the heavy duty model(s). For example, the transfer case is a heavy duty unit (same as in FJ62 I believe). The A343F is found in the FZJ80 and UZJ100. The R151F is found in the PZJ77 and newer HZJ7x. The steering box is actually the same housing between LJ7x and HZJ7x. Body is basically the same as the HZJ77 from the firewall back. Frame is the same strength (just has different suspension mounts). Heck, they share the same repair manual even (RM183E).
It's the LJ7x engines that Toyota really F'ed up. They never should have put a 2.4 into a 2200kg vehicle.
Since Kurt hasnt offered one, i dont think Cruiser outfitters may have one in stock, but maybe they can source. Ive gotten glass from Steve @SteveJackson from Land Cruisers direct before when i went in for some windshield rust repair. You also have a good resource with Valley hybrids/Cruiser brothers... they are in your neck of the woods and might be able to help out sourcing as well. Good luck. Just dont break any of your rear windows, they suck to source, ask me how i know :-)
Since Kurt hasnt offered one, i dont think Cruiser outfitters may have one in stock, but maybe they can source. Ive gotten glass from Steve @SteveJackson from Land Cruisers direct before when i went in for some windshield rust repair. You also have a good resource with Valley hybrids/Cruiser brothers... they are in your neck of the woods and might be able to help out sourcing as well. Good luck. Just dont break any of your rear windows, they suck to source, ask me how i know :)
We stock the glass :D
