Issue with rear window regulator......
Orlando, FL & Southampton, NY
Last weekend, my left rear window was a bit slow going down :meh:
All of a sudden, I heard a pop and it would no longer go up or down :oops:
Went straight home, pulled off the panel and found that the rubber seal that attaches to the rail slipped off the bottom of the glass :doh:
I cleaned up the rubber as it was a bit greasy, lubed up the inside of the rail where the wheel for the regulator glides back and forth, then attempted to slip the window back into the rubber seal, but it was being a little bitch :mad:
Sprayed a little soapy water and with a bit of force, was able to finally wiggle it back into place :smokin:
She sat for a week and earlier today, I decided to lubed all of the runs with silicone spray.
Went up and down about 20 times with ease, then all of a sudden, while going down, I heard the same pop and the window stopped about 2 inches down :bang:
Pushed the window up by hand and just taped it in place cause it started snowing again :eek:
I'll take it to my shop and tear her down again next week, but how do I go about preventing the rubber strip from popping off of the glass?
I glued the glass and rubber liner into that channel with silicon. It's been fine for about 10 years.
I know, I should have used TOYOTA silicon...
Did you glue the rubber to the rail/channel or did you glue the glass to the rubber?
The problem I have is the rubber (and rail) popping off of the glass :confused:
The rubber remains in the rail
I'm pretty sure I put a bead between all three. Almost positively sure. I've practiced step #6 repeatedly since then...
Opened it up tonight after replacing the LF window motor
Took the rubber out and gave it a good cleaning with hot water.
Cleaned out all the rust from the rail, then added a thin bead of FIPG before putting the rubber back in (none in the rubber itself)
Sprayed the window with soapy water, then slid it into place.
After it dried, it I couldn't even pry it off, so I guess it's good :cool:
Greased up the track, then dry lubed the runs.
Probably went up and down about 60 times without issue :)
It's probably not a good idea, but I was frustrated with mine and used channel-lock pliers to squeeze the metal tighter against the glass. It's stayed put for several months since.
Incidentally, I noticed a part number change on that groved metal part in 95 or so. Maybe the later version is better designed.
