Is this carb hooked up correctly?
en route
I bought and installed a rebuilt Aisan carb on my 8/73 F. In the pic below, the fuel delivery line is connected on the side, from the left side of the photo, and the fuel return line comes out the top, through the banjo fitting and the hard line coming toward you in the photo. With the hard lines I received this was the only way it fit. Is this correct?
Also I found a wire coming out of the firewall not hooked up to anything, in a group of three wires, two of which were connected to temp sensors on the manifold. I hooked this wire, which puts out 12 volts when the ignition is on, to the idle solenoid wire because the connector fit. Is this correct?
I think the way I have things connected works, but I clogged the fuel filter after ten minutes of unsuccessfully trying to make the engine idle. (This Cruiser had been sitting since 1992 when I acquired it last fall - I'm just now getting it running.)
Sounds like time to inspect the gas tank. And you might get a clear fuel filter. What kind of stuff are you getting in the fuel filter to clog it. Rust, Paint, sludge...?
All looks good and agree with troll hole. I got a clear filter, and its nice because I can see the rust particles being trapped when they are sucked out of the tank, Mine sat for several years as well.
Hi All:
You appear to have the same Aisen carb that I have on my 11/73 FJ40. Yes, I believe you have everything hooked-up correctly.
If your fuel filter got clogged-up so quickly, I'd suggest considering disconnecting the fuel line from the gas tank and running it to a one gallon gas can - see if you can get the truck to run well at idle and higher RPMs from this known clean source of fuel - it sounds like that gas tank has gotten really rusty over the last 13 years!
Good luck with the rig!
Regards,
Alan
Seattle
Agree on the fuel filter ideas. I put a new one in when I had similar issues and cut the old one open. It was loaded with crap. Kept the new one on for a few months and then replaced that and cut it open - not much rust. You can also run an in-line glass or clear filter between the fuel pump and the carb to see if any rust is getting past the filter and pump and headed into your carb.
Make sure this is good and also that you fuel pump is good before moving on to other potential issues. Once you know fuel delivery is solid, you can start addressing other issues that may impact idle (vac leaks, carb adjustments, etc...).
Also - make sure your PCV valve is solidly connected also. You won't get an idle if this is not working properly. I'd replace the PCV valve and hose as its cheap and a good thing to do anyway.
AndrewT
You got it right. When I rebuilt mine, I got the two lines reversed. It ran but died repeatidly, duh. Nice looking carb BTW.
Thanks for the excellent advice as always guys. Don't know what's clogging it as the filter is OEM metal.
I already bought some cheapo Napa clear filters to try (the truck is at my camp, an hour drive from home, so it only gets weekend attention).
When I first got the truck it had a goofy electric fuel pump, which was convenient because I used it to flush about three gallons of fuel through the tank and out the lines, moving a LOT of gooey cloudy sludge, but little rust. The electric pump will now be used to drain toilet bowls when I winterize the cabin. :)
Fuel pump is brand new OEM from CDan, and was correctly filling the carb bowl, with the fuel level at half way up the sight glass, for about 10 minutes of running, then stopped. Pretty sure it's the filter getting clogged - probably dislodged something in the tank when I took my first celebratory drive around the property when I first got it mobile.
The PCV valve and hose are brand new OEM. The arrow on the side that says "toward manifold" I assume means toward the intake manifold, away from the crankcase?
I do think I have a vacuum leak somewhere - kinda localized it to somewhere behind the carb and at its base by spraying carb cleaner around while the engine was running. I think maybe I need a new manifold gasket, or possibly a cracked intake manifold - pretty sure the heat riser valve is stuck, but don't know in what position...
Yes, the carb is like brand new. It's a Jim Chenoweth rebuild.
Sounds like you are making progress. Good luck.
For the vac leaks, you can better localize them by using a piece of heater hose (or garden hose or any flexible tubing) as a stethoscope - one end on your ear and probe the other end around the carb, intake, manifold area, etc.. Vac leaks will sound like hissing noise - you'll learn what it sounds like and get better at pinpointing the leaks (if you have them).
AndrewT
