Is Slow Acceleration Normal?
Easy. ha ha
Yeah i know that but thanks for the lesson any way. they sell clearance light kits and that is how they are installed on trucks that don't already have them. Like on single rear wheel heavy duty's that didn't get them from the factory.
I love my 3FE. I tightened the throttle cable and the tranny kick-down cable. Advanced timing (running on super unleaded though), added 4:88 gears when I rebuilt the axles. I now Have 33" tires, but ran the 4:88's witht he stock tires with no problems. Actually the tranny shifted better than stock, and better with the stock tires vs the 33's.
I don't like the tranny, it doesn't shift very well. The thing will go from 3rd gear to 4th and then lock-up immediately. If I keep my foot into the accelerator, I can pick up speed pretty fast. I'm thinking of doing a 4L80 E swap, and I might just go ahead and do the 350 LT1 swap too. My main thing is to get it to tow, and cruise interstate with more power. I love the platform.
Right now I just take it easy. As it has been said, the 3FE is a tractor motor, and will get the job done. I just enjoy the little mighty 3FE for now.... But then it's going to get swapped out. I think the 350 LT1, 4L80 E with upgraded manual shift body, atlas t-case, and so on would be sweet in this rig.
My 91 is the same way, the 94 is much better, but still not a speed demon.
4th gear TC lockup is based on output shaft speed (no electronics in the A440F). With stock gears and tires that equates to approx 45 MPH. With 4.88s and 33s you're probably going above lockup speed according to the tranny. Either that or you have a stuck valve. I have 4.56 and run 33s on the street. My lockup is very close to stock.
FWIW, the modified valve body from WholesaleAutomatics (Rodney) is supposed to be a magic wake up call for the A440F. I have considered this on several occasions, but I just don't put enough miles on the beast to justify the cost.
When I bought the 80 (stock gears) I spent a lot of time shifting manually. If I didn't shift it manually, getting on the interstate was scary. I could not pick up speed quickly.
Our Interstate speeds are 70MPH, and many on ramps are short. With the 4:88's I'm fine as long as I stay on the gas. If someone in front of me slows a bit. Then I'm into 4 lock-up. That makes sense that the lock-up will act sooner with the gears and 33's, it will kick in at 35MPH. I still shift manually getting on the interstate if someone is in front of me.
My point then, is that you can be pretty happy with the 'ol 80 models with the 440, if you shift it manually. All research I've done on this here, basically think thats allright for the tranny. The gears are a worthy addition if your 80's d-trane is in good shape. For less than $1000 bucks you can re gear and ad a locker in the rear.
The early 80's, well all 80 series, amaze me. I have 190,000 miles on mine. The thing is tight craftmanship.
i just did that the other day, and it helps out the peppyness a bit.:D
I'll give that a try. I'll do that when I tighten my water valve.
Also the lights, I'll just black tape them or put them in that black tube pictured there and just run it the way I had it, no big deal.
Well, just did it both things. The throttle adjustment really helps. I went almost all the way till the end it made a big difference! Thank you!
Also, any reason why my second gear is a pansy? Like, first gear ('L') is awesome, but when I put it into '2' and it shifts into second, damn, uphill the engine is chugging but its barely moving. You think I'm getting too much slippage on that gear or something? On flat ground its good but up hill doesn't do anything. Third gear does more!
Red Beard,
You may want to keep in mind that this is a 5000 pound vehicle in stock form. Additional weight comes from stereo upgrades, extra jacks and a driver.
With fuel prices approaching $3 a gallon, i would advise that you get out of the habit of looking straight ahead while concentrating on getting to your destination as fast as possible. Try to enjoy your drive by kooking around at the surrounding area.
The safest way to do this other than stopping is to keep it slow. :idea:
The LC is IMHO the BEST vehicle for all driving conditions both on and off road.
Noone builds it better. Period. :cheers:
I think you might of misunderstood that statement. I don't mind going slow, as long as nothing is wrong with the engine. I just though my second gear feels weird compared to the others.
Yeah, I agree. The Land Cruiser is the best all around vehicle around. That's why its so damn expensive!
what about a....
done deal now..... but did anyone mention a cold air intake???? Sure helped me
Glad I read.....tightng the trttle cble tomorrow!!!! better w/ high octane too.
I think someone said that.
High octane with advanced timing. :D
Also, I found out my EGR system is not doing well. A chewed up looking hose and a broken "PVC" valve. Not good if you want to get up to speed. Hopefully that's all it is for now.
Also, I over tightened my throttle for fun, and man, my transmission was out of wack. It would go into neutral when shifting gears. So don't go crazy.
NOT something you would want to do. Those oiled filters let more dust and crap go through, along with the oil itself, which can clog the air meter... I've got a K&N in mine right now, soon to be thrown out for an OEM washable. There is a layer of oil through the length of my intake tube.
Oil??
dont oil it....I dont. Yah it wont last the life time but there not horribly
expensive. I've sprayed a little silicon on it an let it dry to try and preserve
it a little...(2 yrs) but I agree with not putting on the oil.
