Ironman Torsion bar help....
Jackson Hole, Wy
I got my new Profoam shocks, coils and torsion bars and....no instructions. Even online info is not clear.
Torsion Bars say LH and RH. I drive a US LHD 100 series. Is RH driver's side pr passenger for me?
Springs say N/S and D/S. I was told D/S was printed for Australia, but nothing in writing.
I am not good with..."I think it is".
Help with experience is appreciated.
Thanks,
Dukes
Measure springs - Longer spring goes on LH-DS.
I'll check my tb's in the morning and let you know which is which- unless someone chimes in earlier
I have just received the toughdog tbars and springs today as well.
Jason said put the taller spring the drivers side. One of my springs is 1/2" taller I would say bye balling it. Just to be sure I'll measure.
Tbar instructions for toughdog say there is a left and a right marked on the bar and that getting it reversed can cause sagging or breakage. Also my bars have a sticker to indicate which end goes toward the front.
On the instruction drawing it uses "D/S" and shows it in the right hand drive side (USA passenger) with clockwise rotation. It calls the other side "P/S" (USA driver) and anti clockwise rotation.
I understand that does not match your markings but hope it helps. If you want a photo of my instructions just let me know.
This is the drawing:
The torsion bars are marked accordingly: RH goes on Right (passenger side) LH to Left side (Driver-US).
Good luck with the install
Thanks,
Dukes
So how is everything?
Can I ask why Ironman vs OME or ToughDog?
Does anyone happen to know which way the Ironman torsionbar is? I mean not left and right, but front and back?
One end is stamped with an arrow, a "Z" (or "N?") and the leter "L" or "R".
