- Joined
- Jun 3, 2014
- Threads
- 2
- Messages
- 6
Proline - any idea on shipping charges to Texas?
Give me your zip code to calculate the shipping chargesProline - any idea on shipping charges to Texas?
It's close, maybe a little bit more than 1/8 of an inch, but that depends on how close to the body you install the bumper, in the frame assembly there is a gap in each hole so the bumper can be moved closer or farther and up and down so the bumper can be perfectly center on the LC200. I only have one in stock right now, but can build more in the shop right now.Nice looking bumper man. Is there much space (gap) between the front quarter panel and the lip of the bumper (where they meet on the side by the tire)?
you keep these in stock?
thanks for sharing
We also did this custom mounts for a LED light bar for the LC200
Yes this is for use with the OEM bumper, we just took the black insert out and did two small cuts ( 1/2" diameter ) inside the bumper to fit the light bar inside ( this was a 41.5" LED bar ). This brackets will work on your LC200.More info please. This is for use with OEM bumper cover?
Do you cut out stock insert?
Last question - does this work on 2008 - 2011 models?
This was installed 6 weeks ago on a TRD supercharged 2013 LC200 that is driving in South Florida ( close to 100 F ) without any overheating or trouble at all.No offense, but I'd never place it there out of respect for Toyota's LC engineering team. That's A LOT of air flow you're blocking.
79606Give me your zip code to calculate the shipping charges
How do you mount the winch, to the bumper itself instead of the mounting plate?Been busy lately at the shop and haven't found time to post the pictures of the bumper in a friend LC200, but here at some of the pics while we installed the bumper:
This is the frame assembly that attach the bumper to the frame
Sent a pmHow do you mount the winch, to the bumper itself instead of the mounting plate?
