Bucfl
Conceptually by cranking up the stock TBs you are also adding more preload to a "spring" that was designed to perform optimally at factory height. Adding preload will affect your ride quality (stiffen), and you loose some travel (droop), and depending how high you go, steering control. Just be aware of the amount of droop you have left over as you crank your stock TBs up. Adding some aftermarket TB's (even set at factory height) would provide more range of adjustment (related to preload) and improved handling.
CV angles on a slight (1-2") front lift can be managed with a diff drop. But....spiders/ujoints, sway bar links, axle alignment can still be affected by lifting.
Reading the IM FAQ's they state that the rear lift is limited to 35mm = 1.375" ?
"Vehicles with Independent Suspension are limited to 35mm lift due to the geometry restraints inherent by this design of suspension."
So maybe there is some conflicting info. Hearing from someone who has installed the IM rear springs, what the "after install" hub to fender measurements would provide some factual data.
Sorry for the continued questions and lack of knowledge.
What Is the safe rake I should have? I know others have 1.5 medium rear spring with cranked TB without diff drop. Will I ruin all those parts you mentioned without a diff drop?
