On my 97 when I crank it over it sounds like the starter runs out of strength for lack of a better word. It will start immediately after though on the next crank. It doesn't do it every time but is frequent enough to be worrisome.
Everything else runs fine. No other electrical issues.
As far as I know the starter and the fusible links are stock. Next dumb question.... Where are the fusible links?
Does it ever just click and not turn over for a few tries as well? Like when the battery is low? Mine was having issues like that and i replaced the contacts and plunger and everything has worked great since. The original starters are worth fixing over getting a parts house reman version. Most will run for a long time with the minor cost of the consumable parts in them.
Sounds like the familiar culprit. Here is a good link that documents the repair. I followed it for my starter fix. And it has the part numbers if yours is the same starter. Starter Motor Contacts
Dealer got the parts in a day or so. Was about $50-60 for the contacts and plunger. Not very difficult to swap. Just be careful when working on the contacts as some of the stuff is plastic on the housing. And don't lose the ball bearing that the plunger sets over. Pretty straightforward repair.
Got my starter installed. Pretty easy. I am going to rebuild the old one. I got a denso reman from Safari Ltd here in Grand Junction. Starts nice and solid now! Fusible links are coming too.
