Interesting issue. Cold Start - No Compression
Staunton, VA
1994 Land Cruiser. Rotella 15-40. Unknown/spotty maintenance history. 11 mpg. No CEL. No oil usage or leaks. I haven't done a compression test other than listening to the starter.
On a cold start (winter and it's sat overnight or longer) the motor turns over like it has very low or no compression. Imagine you took your plugs out and hit the the key. It always starts and I don't have to crank it any longer than normal. After it starts it runs fine. Drives fine. Idles fine. WOT fine. This started pretty much out of the blue. It was not a gradual thing.
On a hot start it starts "normal". You can hear the starter compress each cylinder. Again, it runs fine in all conditions.
I'm wondering if the cylinders are being washed down overnight due to leaky injectors or a bad fuel pressure regulator?
I'm open to other suggestions.
Seems unlikely that all injectors would leak at the same rate.. and start doing so all at once.
If the FPR were bad that should cause a rich condition when running.
Maybe something is going on with the idle air control valve? Like for some reason it closes completely on cold start, thereby keeping much air mass from entering the cylinders and lowering compression?
Either way I'm curious what you find out about this one. Seems like it could be tough to track down.
What is the temp there when starting?
So does the motor turn over fast or slow when cold starting?
If its below zero, the thick oil makes it hard for the motor to turn over. Maybe the thick oil is affecting the rings and reducing compression (just a guess). Change to a 5w 30, 5w40, 10w30 or 10w40 and see what happens. If it does it with the lighter oils, then I have no idea what it is.
Looks like its been down to 9 deg F last 7 days. That at the bottom of the range for your oil. Its getting thick at that temp.
80-series-oil-viscosity-jpg.621854
Well, then I would say there's not much of an issue here. If there was no compression your motor wouldn't run.
If it starts and runs OK, if there is no loss of power, if there is no change in MPG, then there is no problem.
BTW, I have taken my plugs out and cranked the starter. It is almost silent.
I think I might go ahead with an oil change before I drive it again and see if that changes anything. Oil is cheap in the grand scheme of things.
MPG is low but this all started about the same time as winter fuel was put out so it's tough to narrow that down. My main concern is that the cylinders are being washed down by leaking fuel and I am doing damage to my motor. I religiously watch the oil pressure and I check the oil every couple days - if fuel is leaking into it I can't tell.
I guess a bad FPR couldn't do this unless the injectors were leaking as well... Worn out or gunked up valve springs? Stretched timing chain? I'm reaching here.
I'll change the oil and report back.
I don't know if this has anything to do with your starting question, and I'm not sure how the "cold weather" OEM starter works, so this is more of a question than an answer. Does your Cruiser have the "cold weather" starter installed. I know they have more cranking power than a standard starter. Just a thought, question.
As previously stated, the chances that all 6 injectors are leaking fuel is pretty remote. If the injectors were leaking fuel, you would have higher than normal compression, not lower.
If this is keeping you up at night, then ship off an oil sample to a lab and get some definitive results.
Hmm. No idea what the difference is. Anyone know if there is a physical difference between the two? or how I would determine this?
Nothing keeps me up at night. However, I do like to avoid things that are actively damaging my motor. If changing the oil doesn't produce any results I'll dig deeper.
You also might want to check some real basic things before delving into this any deeper. Are your spark plugs tight? Had this issue with an FJ40 some years back. Owner complained about poor economy and lack of power. Went to do a simple tune up and was able to unscrew all 6 plugs with my fingers. Truck started and idled fine.
To find out definitively whether your cylinders are getting washed down and oil diluted with fuel, order a used oil analysis kit and wait for the sample bottle to arrive before you change your oil. Make sure the profile you pay for includes fuel dilution. Polaris, blackstone, and amsoil all sell these tests (amsoil is my current favorite, when considering cost/convenience/results)
Fuel dilution is one of the many things you'll get from such a test. Yes, it is another ~$30 on top of an oil change, but like I said you'll know definitively whether your injectors are leaking.
That would be hilarious. However, not out of the question. This thing sat for years with a transplanted "low mileage" (according to the PO) motor before I picked it up and starter driving it regularly. Honestly, it has run so well the last year I haven't even bothered to look at the plugs. Much less tune anything up.... This could be a self-inflicted issue.
Welp. Already changed the oil with some Rotella 10-30, so it's too late for that. I should know if it worked later tonight after I let it cool off.
The LC needs a basic tune-up, regardless. I'll do that and if the issue persists I'll have the oil tested. Good advice.
Ok. Switched to 10w-30 and after two "cold" starts it has been totally normal. Granted both starts it was probably 35 degrees, but it would do it at that temperature before. I'm not going to say it's fixed, but it seems like it's fixed. I've got to go out of town for a week so I'll check when I get back.
That being said, any ideas why an oil that was too thick would make the motor act like it had 0 compression for the first couple turns? The PO said he swapped in a motor with 32k miles on it. Maybe it's true and the oil was simply too heavy to fill all the nooks and crannys when it is 15* outside?
There has to be another mudder with a better guess....
Could it be starter gear slipping on the ring gear from worn teeth? What could seem like low compression turning over might be the teeth slipping. Some spots could be worn more than others making it intermittent depending where the flywheel stopped last
That would make a most horrible sound.
To bring closure to this thread:
After a couple more starts with 10-30 in the old girl I think it's all taken care of. I never knew a too thick oil could have that affect on a motor. I also thought I remembered reading a couple threads where people were running 15-40 with no issue year-round, however, that was certainly the problem for me.
Compression in an engine with a few miles on it is generally lower when the engine cold, the rings and piston clearance is catered for when the engine warms and the expand. Another thing that can happen on engines that have plenty of miles on them, is a ring of carbon builds up around the valve stems, this can cause valves to be held slightly open, not enough to hit the pistons but enough to prevent sealing up correctly.
This of course allows the engine to spin quicker when cold, the engine once started allows the valves to close (warmth and speed of movement)and all is well. Keep an eye out for an idle misfire that disappears when the revs are raised, in the future if this happens then refer back here as you have found the problem.
regards
Dave
