Interesting accidental reverse light fix
Decatur GA
I thought I would bring this up just because it accidentally saved me some time. When I bought my truck a few months ago my reverse lights did not work. One more thing on my list that wasn't really important. I though I was going to have to start at the lights and work my way back. At the same time, my reverse light on my dash did not work either. But it would flash a little when shifting in between park and drive. I just assumed it was a dirty contact somewhere in the shift lever. Low and behold, the two were related. I just got back from a ten mile off road trip and whatever I did jogged the connection back into place and both my rear lights and dash light work again.
Is there an easy way to get into those contacts so I can give them a good cleaning? Is it something that should be replaced? And while I am asking, are there lights on the gear shift that tell what gear you are in like many other vehicles? The only lights are on my dash. I don't really care, but if it is supposed to be lit when my lights are on, I would like to replace the lighting.
I think the gear indicator lights are only on the dash. "D" quite commonly doesn't light up. I was happier when I thought that was intentional.
Thanks, Mud!
I don't know where the reverse contacts are.
It seems to me like all the contacts are in the same place there in the gear shift area. I need to look it up in the manual. I just replaced my Drive light with the airbag light. ;)
I am sorry to say that I really did nothing but run off road for ten miles really hard! The contact for the light must have been dirty or loose. Neither my reverse light on my dash nor my reverse lights worked. The next day after running hard, I freaked out when I backed up down my driveway and saw the orange "R" light on my dash. I put on the parking break and took a look at the rear end and low and behold my reverse lights were on. I am sorry I could not explain what happened, but I can only imagine that the connection is there a the gearshift. The reason I think that is because while putting it in gear, the reverse light flickers just a little bit until it is perfectly seated in reverse. I want to take it out and give it a good contact cleaning. I know that has to be the issue. So that would be my suggestion. But since I have not actually disassembled it yet, I cannot tell you more about the mechanism. I would hate to advise you to just run the gear shift back and forth 20 times to try and clear the contact, but it might just work. Does not sound like a good (or very professional) idea though.
This switch is commonly referred to as the Neutral Safety Switch or Transmission Range Switch. It is mounted to the transmission, where the shift linkage attaches to the shift shaft. It is an adjustable switch, so improper installation or other repairs can cause it to either keep the engine from starting, not illuminate the reverse lights, or affect transmission shifting.
Typically, the switch is not disassembled or repaired, only adjusted or replaced. I suppose you could attempt a repair, but be ready to buy a new one if that doesn't work.
Does it connect to the famous 10 amp Gauge circuit in any way?
Yes, it receives power from the Gauge fuse to turn on the indicator lights.
