- Joined
- Jun 29, 2007
- Threads
- 45
- Messages
- 1,539
According to several posts all over the web real world observation on EGT's show that an intercooler reduce EGT's by 1-200 degrees fahrenheit.
Christian, what is the relationship of EGT to engine coolant temp? And what happens to turbo effectiveness by lowering the EGT's?
I thought having the turbo receive hot, expanded gasses was a benefit???
Most people I have seen here are considering a intercooler not for lowering EGT's, but more for lowering the charged air temperature. Maybe you can explain this to me and help me understand your point of view.
However while the front of the truck may seem very compact, the tunnel where the radiator sits is almost 3 feet deep, before you reach the engine. So there is a lot of room actually.
That's great! Your intercooler and radiator will be well protected. I recommend installing your intercooler with an electric fan with temperature operated or constant fan, for those times when you are crawling overland and not pushing so much air!!!
We are actually planning to use the internals of the R150F paired with a 5th gear from a R452 thus geatting a 0.7:1 fifth gear. With Michelin XZL 11/16 tires we will be doing 37 km/h at 1000 revs in fifth.!
Christian, are you including the differential and portal gear ratios? What will your kmph be at 2200rpm? This is an important number, as the motor makes maximum torque here.
Looks really good! Who will make your fibreglass house?
Rick
. Keep about 160 with intercooler you will be fine.
...keep some pressure in it
