Intake tube split-falling apart
This stinkin' rubber pipe that goes from the MAF to the throttle body is splitting on me and I am keeping it together with duct tape right now. Anyone know where we can get a new one besides the stealership? They want 100 something bucks for this piece! Nutty.
Contact cruiserdan tommorrow. His contact info is in the vendor section.
and dont say stealership to him
Identify yourself as a mud member and he will give you a hefty discount in is role as Parts Manager for American Toyota. You add a filter or two to get your order over $100 and he ships for free with no tax :)
I wouldn't disrespect Dan...I have seen his name all over the board and he seems to do good by everyone here. That is an amazing steal...:D I mean deal at $60. I will call him tomorrow. Thanks for the help.
I think its a bit more than $60, but he will tell you
I destroyed my 14 year old intake on a Thursday night while installing the new parts I had ordered from Dan. Dan is excellent about getting shipments out, but I couldn't wait so I paid around $106 for mine from the dealer in North Scottsdale who had one in stock.
I went through Dan it ended up being 78 + shipping. I threw in a air filter too. Thanks for the tips. I duct taped it for now, but don't need to drive it so it will sit until the part gets here. Now onto the EGR pipe clean out...yep...I have the dreaded p0401 code. Thanks all.
I am 99% certain nobody has ever fixed a P0401 by cleaning the EGR pipe or "cleaning" the EGR valve. You can sometimes fix a P0401 by cleaning the EGR modulator and you can frequently fix a P0401 if the small tube through the intake is clogged. Most have found that replacing the VSV for EGR is required but you'd best test it and the other components first. You'll save money that way.
Sometimes it is as simple as an EGR hose that has come loose.
-B-
Free shipping? Is that still the deal?
I had to discontinue that in order to keep the cost of the parts down.
-B-
Thanks for the advice. I am still working out when this is going to happen but I should do it and be done with it. Who do you guys get to test the parts?
Test per the FSM
-B-
never mind - Dan answered the shipping question. Sorry for the bad info
You have to order over $100. $99 wont get iit, but I would confirm with him. You need to identify yourself as a mud member
See post #13
Test per the FSM
-B-
X2, If you dont have a FSM, do some searching here. Lots of info on the EGR system and some threads have tid bits of the FSM tests and what others have done to remedy that CEL code :)
GL
GL
I have been reading my arse off about the stinkin' EGR system it seems to be Toyota's weakness or is it CA weakness. I can't figure out which.
The VSV for EGR seems to fail prematurely (if you consider 100k miles as premature) and since it is the most difficult part of the system to get to, people replace everything else except that piece and then piss and moan about how much trouble they are having with the EGR system. The EGR system is for all of North America so everyone on this side of the pond gets to join in the fun.
I have a theory that a failed or failing VSV that is not replaced will eventually lead to clogged EGR passages and hoses and a clogged EGR modulator. Run the system tests including the test of the VSV for EGR, fix the problem and get on with your life. It really isn't as tough (~60 min fix) as threads here in the 80-section would lead you to believe.
Adding to the mystique of the P0401 is the fact that some VSV failures are intermittent and sometimes the VSV test in the FSM will pass. See Raven's thread for an example.
-B-
