D
Deleted member 159334
- Joined
- Sep 15, 2019
- Threads
- 2
- Messages
- 27
Had an intake manifold leak so replaced the intake manifold gasket 1977 FJ40....put the OEM replacement gasket in.....initially, I thought the problem was solved. After I replaced the gasket, I sprayed a little brake cleaner along the manifold and the engine idled steady so I thought I had no leak now and all was good. That was about two weeks ago and I haven’t driven it much. So then I worked on the carb tonight and adjusted it with the lean drop method....so runs great now....seems to have more power.....so I sprayed a little brake cleaner along the manifold gasket again and my engine idled up .....manifold leak again!! ?
Do I try to retorque the bolts? Just leave it? I had a good vacuum level on the manometer when I adjusted the carb tonight and it seems to run great.
