installing chev alt....
City that rhymes with fun
im gonna be tryin to instal a 90 chev alt in place of my stock one on my 71/40. i cant seem to find info on doin this swap out. any help is always appreciated.....its got an F engine
not too difficult. Depending on what alternator you get there may be some things you'll need to do about the pulley(s) and the mount. The wiring is pretty simple whether you use a single wire or three wire alternator.
There's tons of information in previous threads as this is a popular project. Probably worth a look in the great FAQs above.
This site is an easy to read guide to both types of installs: http://madelectrical.com/
Do a search on 12si...tons of info
I needed the following for my 12si (3wire) install (1F):
Diode
2F alternator bracket
new alternator belt
trainrech said:
One wire is nice, but they need pretty high engine RPM to self-excite.
You are referring to a no wire alternator (the wire that connects the output of the alternator to the battery is a given). A one wire alternator uses a 12v line that is activated by the ignition key and has no requirement for RPM excitation. The one wire alternator has about 14.4V at idle. A one wire alternator is very simple to add, given it has the correct pulley (double is best) for the Toyota stock belts. A spacer and tension bracket would be needed. A wire from the fuse panel that is off when the ignition switch is off and on when the ignition switch is in the start and on positions. If you wire the alternator internal voltage regulator to constant 12v on, you will drain your battery. This photo is a one wire 200 amp GM alternator. The connector has all four wires, but only one is used. I do not like to cut off wires at the connector as they will eventually corrode through the connector.
Actually, your explanation is one wire off. Here's an excerpt from www.alternatorparts.com ...
_________________________
What is a self-exciting, one - two - three wire alternator?
Self-Exciting Alternator:
Is an alternator that uses a special voltage regulator that doesn't need an ignition wire to activate it. This type alternator only requires a battery wire hooked to it. The voltage regulator contains circuitry that uses the residual magnetism in the alternators fields to determine when to turn the alternator on. The regulator does this by sensing the RPM the alternator is turning, when it gets to a certain rpm the voltage regulator "turns on". Typically you start the vehicle, rev the motor slightly then alternator starts charging. This type alternator is commonly used on custom cars & trucks, tractors and other non standard applications when wiring is a factor. In choosing this type alternator you must consider, do you want to rev your motor slightly to get the alternator to turn on. Also when using the self-exciting alternator on tractors or other slow turning motors does the engine have enough RPM's to start the alternator charging. This can be overcome by using a smaller pulley or by adding an ignition wire.
One-wire Alternator:
Is another name for the Self-Exciting Alternator mentioned above. You only need connect the battery wire (one-wire).
Two-wire Alternator:
Most standard and all self-exciting regulator alternators will work using the two wire setup. Two wire means that you use the battery wire and an ignition wire to activate the alternator. With this setup the alternator starts charging as soon as the engine is running
Three-wire Alternator:
This setup uses a battery wire, ignition/warning light wire and voltage sensing wire, Three wires.
___________________________
I installed a modified CS-130 on my 40 - single wire to battery only and wasn't able to turn enough RPM's to get it to excite. Scott at Mobi-Arc further modified it to work with a Mobi-Arc 200, so now it is an externally regulated 2-wire alternator.
