- Joined
- Jul 20, 2004
- Threads
- 274
- Messages
- 23,204
- Location
- Chandler, AZ
- Website
- www.tontorecreationalliance.org
Check your nutz!
Check your nutz!![]()
No kidding. Had visually checked not long ago and two of them are gone.
Check yer nutz after every wild ride![]()
Hey Kevin
Should we be putting some lok-tite on these bolts/nutz??
Hey Kevin
Nay
I got my Trxus tires finally. They are 35" and so far they are pretty round. I took Chad's (creeper sleeper) advise and had Les Schwab mount them and air them up to 80 psi for 24 hours. They stuck them in the back room with heat. We'll see what happens with balance. So far I like them alot. They are not really that loud and the 80 seems to handle nicer than before... ... I had really crappy tires before..
I do not have a lift on yet (still waiting on Slee's 4" or FOR's kit, both are on backorder)... I am surprised that they fit and also they do not rub when just on the highway. I went on some dirt roads with big ruts today and they rubbed a few times . I am really amazed that they don't rub more than they do... They are big tires.
Initial impressions.... me likey....![]()
) with the base being pretty icy due to the still relatively warm ground. The trxus are better, they just stick to everything, with the Toyos you can get some tail wag and have some fun - they do very well, but you just don't feel quite as planted.Overall right now I'd say I think the trxus track better and are a lot quieter. That is probably worth a difference in roundness - report back on your results with the 80 PSI in a warm room method.
So far the tires are pretty smooth. I can't remember how much Les Schwab said they put on to balance the tires... It is smoother than my old tires. I do still have a pull to the right and will get another alignment check after lifting the truck. When I had it checked before the alignment was OK... Not sure why the pull to the right. I am running 32 PSI in the tires.... I think this is where you said to run them. I have rebuilt the front end with new rotors, brakes, bearings, grease etc....
These tires barely fit at full stuff, the tread width definitely makes a difference and I can just get them to rub. :
I was actually able to get a tiny bit of rubbing on the upper spring perch in the front wheel wells.
i'll add to this thread.
Took my 35" truxus in to be rebalanced again on Friday. They weren't bad but i had a little wobble feeling around 45 mph that would smooth out at highway speed.
Anyways, the guy came back to me and said 3 of the tires were perfect and didn't need a thing. One on the other hand required a lot of weight. That is the exact same thing that happened with my set of 33" truxus, 3 of 4 were perfect and one was a pain.
35's
F.O.R.
rubbing
Did they try breaking the beads and rotating the tire on the rim 90*? If you try that a couple times it might seat up better or move the weight inconsistencies of the tire and rim? to offset each other. Worth a try if they didn't do it already.
It's the width of the Toyos at the tread - they are a much wider tire than a typical 35x12.5 due to the squared off tread pattern. No rubbing with the 35" Trxus MT's I had on previously.
The only difference between F.O.R. with a 2" bumpstop drop and any other kit with a 2" bumpstop drop (i.e. designed for 35's) is the F.O.R. shocks don't have as much travel so you don't get as much angle into the wheel well at full articulation. A wider tire will make up for this in a hurry
It is not noticeable during wheeling, I never felt it. Just the visual on the inside of the wheel well.
Just a data point...
No rubbing at all in the front with Toyo 315/OME med/and stock bumpstops. (I haven't been able to make it happen during the last 2 years.) The rear on the other hand required a drop to accomodate full stuff. [hijack off]
I got the front rub after a 3 foot wheelstand that occurred with some momentum coming up this climb. Notice the strange position of the front driver's side tire![]()
I finally sold my Toyos...
and
lol.....
