Injector cleaning
Topeka, Kansas
I am going to remove my injectors and have them cleaned and matched. And also clean out throttle body. But my question from others who have done this what is important or best to do while having this can of worms opened up? Is it necessary to replace the fuel regulator at the same time?
If the FPR is working fine there's no need to replace it. The obvious things to replace at the same time would be the fuel filter and the filter/"sock" that goes on the fuel pump before you put the new injectors back in.
Interesting, I hadn't thought of doing the fuel sock at the same time as the injectors. Is this a problem with the 80's?
I'm not particularly familiar with the gas engines, but don't you have to remove at least part of the intake plenum to access the injectors? If so, doesn't that open up access for the PHH? And also maybe that troublesome harness that gets burnt by the egr pipe?
I'd also clean up the inside of the intake plenum completely.
Of course one thing to really definitely replace is the orings to the injectors. I also agree with baktasht that fuel filter and fuel sock are wise to replace too. Not that it wasn't working well but I also replaced the Fuel Pressure Regulator "while I was there". HTH :cheers:
I have already done the Fuel filter and fuel sock in the tank. I have ordered the O-rings for injectors, and gaskets for the IAC and throttle body, TB will also get a good cleaning. Does anyone know if the PHH is actally easier with the top half torn apart like this or not? I went ahead and ordered the blue PHH kit anyway. And how important is it to use Toyota red coolant?
For doing the PHH while the upper manifold is off is sort of easier. I think, I did mine while I was doing the head gasket so I'm guessing here. As for using Toyota red it is not necessary but if you choose to switch make sure you do a THOROUGH flush of the old fluid.
Since it seems like you're being anal about have a clean fuel system might I suggest that you pull the lower part of the manifold as well and have the two halves pressure washed to clean out all the carbon that has accumulated in there. Then it really will be easy to do the PHH. On the flip side, pulling the lower half of the manifold is a serious PITA. And get IdahoDoug's head gasket DVD as is has some really good tips as one has to do what you're doing to replace the head gasket and its all documented there.
