Still have the original alternator on my truck, with new brushes.
Engine running no accessories, voltage is fine.
First major accessory that I turn on, (heater fan, headlights) voltage drops a volt. Can't even maintain voltage at 1500 rpm.
Alternators are not overly complicated beasts. If the brushes are new, and the alternator makes the correct voltage, but just cannot keep up with any significant power demands, what gives?
Since it can make the right voltage at low power requirements we know that:
The rotor is not grounded
The stator is not grounded
the brushes are new and not the problem
the VR must be working
the only major part that leaves is the rectifier. Which can only be tested for infinite resistance in one direction. (either works or doesn't).
I'm not going to put an aftermarket alternator on the truck, and I can't really afford an OEM right now, so I'm going to investigate a little more.
All I have left to try is to check the rectifier assy, and ground the F terminal and see if the voltage output goes through the roof like it should, and clean the commutator.
Any suggestions are certainly welcome.
