... Im blanking on the pressure requirements for the motor. Would I then be able to use the vette filter/ regulator with the in line pump, or would I just be relying on the FPR on the motor?
I'm guessing that the pressure is supposed to be about 60 psi, but I don't know that as a fact. I googled and found references like that, but that's similar to mine so it's probably not far off. Any pump that's rated for fuel injection would probably do that pressure. Many pumps are rated for a horsepower number which is a decent indicator of flow and pressure capability combined. If you saw that a pump is good for 500 or more horses in a fuel injected application, it's hard to imagine that it wouldn't give you everything you need. As far as brands, I have zero personal experience with this stuff and went on recommendations, myself. Aeromotive came highly recommended and so did Bosch.
I also don't know anything about the stock regulator and fuel rail system on your engine. I don't think it's a flow-through system so I think that means you need to have either a fuel pump with a built in bypass/regulator to dump the excess back into the tank, or else you have to use a pump followed by a regulator that dumps the excess back to the tank (or else replace everything with a flow through fuel system...) Then the pressure regulator up at the fuel rails is just to put the pressure right where the injectors expect it.
So the return then should be NEXT to the pick up? This is to keep the motors run off feeding the pump, right?
That's exactly what I'm thinking. If you return the excess back into the sump, then when you're drawing off of the isolated sump, it's only depleted by what you actually burn... and maybe what spills out despite your efforts to contain it.
So off the pick up, next item in line would be the PRE filter, then the pump, and then another filter? Seems that lots of folks put a shut off valve off the inlet? Im assuming that is to make changes to the pump and filter(s) easier? Im planning on AN fittings, and considering the cost of those...this will add up quick. Do I run all this off hard line, or could I use the soft rubber twist tight hose?
The pre-filter is to protect the pump. The post-filter is to protect the injectors. A valve is a GREAT idea so that you can service the fuel line/pump/filters without spilling a lot of fuel. It's also a GREAT idea for when you wreck and you think your car is about to catch fire, or you're on your lid and fuel is dribbling on the ground from a cut fuel line. I've got valves in-line in all three hoses to the tank. The fuel line has one, the return line has one and the breather has one.
My pre-filter has an integrated ball valve, so that's the one in the fuel line. All my valves are on top so that they're readily accessible in an emergency:
Basic hose and hose-end technology is a clean and efficient way to hook all this stuff together. It's forgiving and intuitive to assemble. If you don't like the result, it's easy to modify. I built a fixture for pressing the hose ends on so that I didn't have to muscle them by hand.
A sump with a hole going into it, and the return line feeding directly in... that seems like a simple and solid way to go whether your fuel pump is on the outside or the inside.
BTW.. I found a pic of my Walbro pickup array going in... this is how I have pickups in all 4 corners. The two that are white-side up are just for show, they go in with the mesh facing down.
