In need of complete 1996 LX450 exaust system
Just a FYI, and not necessarily a recommendation, but in a recent thread, it was mentioned that if you have the dealer replace your exhaust with OEM exhaust, it will be warrantied for as long as you own the car.
Any decent exhaust should have the same. I believe Baktash has said the same about his.
Yup, ours is warrantied for life, including the catalytic convertor and the muffler
The PAIR system has two bungs on the exhaust (1 per 3 cylinders) that it pulls some exhaust from. The ODB-I 1FZ's had them, the ODB-II 1FZ's don't. From what I've read from people who have removed theirs, they've taken the O2 sensors and dropped them into the open holes left from removing the PAIR system. If Baktash can do an exhaust system with no O2 sensor bungs (seems simple to me) then that'd be perfect as you wouldn't have to close up the holes left either by the PAIR system or the standard O2 bungs.
There's a couple of write ups on it, if you read through them I think it'll make more sense.
Starting to make sense to me now that I went and took a closer look under the hood. Still can't find any threads on how to do the conversion but it does seem straight forward. Can I bother your for a link or more specific keywords to search? If the bungs need to be welded on the manifold not sure I'd want to chance it cracking over time (bad experiences in the past...not with a cruiser though).
Gotmud removed his and has some writeups scattered around. It's briefly mentioned here:
https://forum.ih8mud.com/80-series-tech/175393-corroded-oil-cooler.html
(Post 12)
If you search around under his name you should find more.
