If I don't use it, will I lose it?
Windsor, CO
Hey guys, I'm pretty new to the '80 series. I had a '93 pickup and a frend of mine told me to engage the 4wd every now and then if I was doing alot of 2wd driving. I know my FZJ is AWD, but should i engage it in low every once in a while with the same philosophy? pobably a dumb question.
Yes, you need to exercise them every so often. Not too often though, once a year may work. My new 80 probably never had the lockers engaged and I spent 20 minutes trying to get them to engage last weekend.
Engage! Engage! Can't hurt and it's fun ;) Just do it on low traction surface (dirt, sand, snow)
About once a month, I go out on a dirt road and put mine in low range, lock the front and rear diffs, lock the transfer case in high range also. I drive several miles, and lock/unlock the diffs a few times. I have found that by doing this, the diffs lock up quicker than when I first got it. It doesn't hurt to keep everything exercised once in awhile.
The lockers can be more reluctant in winter, (grease is stiffer) which is when I need them most. So be sure to exercise in winter too!
Oh and, excercise your a/c in winter too, the lube in the refrigerant will keep the seals from drying out, and help maintain a good charge.:steer:
how about exercising the lockers while actually wheeling - now there's a concept :hillbilly:
I know this a dumb question, but exactly how do you engage the lockers? I know I saw a post on here about it, but I can't seem to find it. I just picked up a 94 with lockers and when I engaged them the lights just blinked and never stayed solid. Of course, the person I bought it from had never engaged them since buying it in 2000 and they probably need some coaxing. Thanks for anyone with the patience to repeat some good advice. Cheers!
