I think we should make a list of things to check, in priority order, for these types of problems. I can't tell you how many posts I've read here with the same symptoms (including my own) as Clemson55's. Note: I am not the best person to do this - I am a mechanical idiot who learns slow and often breaks things in the process.
Given above - I'd rule out fuel delivery first. Make sure pump is working. My vac gauge also tests fuel pressure. If your engine will run, disconnect lines somewhere between pump and carb and insert gauge - start it (fuel in line is enough) and get a reading. Stock fuel pump should put out about 3-4PSI. Also check gas filter. Take the one you have out and cut it open to check for rust/particles, etc.. - Install new clean one so you know that is good.
If your rig sat for a while, other things could be wrong. Carb could be dirty and/or clogged. If it runs, dump some seafoam in there and try and clean it - then do the quick fix Poser posts often about removing air cleaner and then using carboard or something to limit air flow into the carb to create greater vacuum which will 'suck' out clogged ports/jets in carb.
After that I'd check vac leaks and emissions items. Note that I had recent similar issue which was caused by a bad PCV valve. Your rig will run like crap and barely idle if your PCV valve is bad. They cost like $3 so just buy a new one and make sure vac line to intake is in good order. The other item I saw someone post (when I was searching to fix another issue) was a cracked dist cap which caused similar issues.
After this I'd be clueless on other potential engine issues (still learning). I would not rule out carb issues which could mean you need to do a more thorough investigation of the carb circuits (idle, acclerator pump, et...). However, I wouldn't assume to early that the issue is carb related (learned that lesson the hard way).
AndrewT
