Idle problems
Jackson, ms
My 1975 FJ40 keeps dying when i slow to stop. When I approach a stop I will put it in neutral and coast to the stop...when the RPM drops off after it has gone into neutral it almost always dies. I have a weber carb. Any ideas as to what could be going wrong?
It always starts up again easily....it just dies at every stop.
I have a buddy who works on cars and he adjusted what i understand as the level of the gas inside the carb. This worked for a few weeks but the problem has gotten worse again...it was really bad today after i took my hardtop off. Could the fact that the truck is lighter have an effect on the engine?
I do not run a Weber, but a lot of guys that do also have a fuel pressure regulator. The stock FJ fuel pump seems to be able to flood a Weber carb.
IIRC, the recommended fuel pressure is 3psi or thereabouts. Ask Poser, he has dialed in a Weber on a 2F.
Maybe you'd be better off if I just bumped.:frown:
GL
Ed
Or..............................ask PinHead............................He knows.:)
hey degnol? i saw your sig line ,and was wondering?I too have a 66,f motor ,3 spd trans, what hei are you useing ,is it on a f or 2f ? do you have pisc? do you /know anyone running one in an f motor?
Thanks
I had a HEI on my 74 F motor, it rocked. I think I went to the local parts house and ordered a distributor for a 78 Camero, cap, rotor, coil. I pulled mine, drilled out the pin, and attacked it to the HEI. It was sweet and made a huge difference.
GL
Ed
+1 - FWIW (though I have a Edlebroc), I put inline a fuel pressure gauge and found it was sending like 7.5-8 psi into the carb and flooding it. so, I then bought a fuel pressure adjuster/regulator and put that inline and dialed it down to 3-4 and no more issues.
but I agree about asking Poser.....
i was wrong about my carb...it is a holley...i think i may have issues with a dirty gas tank...my carb keeps filling up with a reddish brown sediment...even though i have a new inline filter right before the carb...
