idle jumping after maintenance
Overdue for state inspection and was getting P0401 EGR insuf..
Pulled the 3 throttle body cables by only turning the nuts just enough to be able to slip them off the bracket.
Pulled the upper intake manifold
Replaced the VSV solenoid
Replaced the EGR actuator/solenoid (blue)
Replaced the valvecover gasket / plug gromets / cleaned
Cleaned the upper intake egr port / EGT sensor / intake etc
Replaced all hose with silicon vacuum hose
Replaced the IAC solenoid on the TB
Reinstalled everything
Now upon starting the truck idled around 2k for about 3-4 mins and slowly started stepping down the rpms until all of a sudden the rpms started jumping around from 2k to 3k and back and forth very frequently. Initial codes were reporting just about everything (iac, map, thottle, egr) cleared. restarted with the same results. Scanned no codes but I think that just b/c i scanned too soon and didn't try and drive it that way. Thinking it maybe throttle cables but not too sure. Thanks!
When you pull the battery cables the computer needs to recalibrate. It takes a few restarts. Mine is idling low since I pulled the battery. In another day or two the engine will be idling as usual on startup.
It was late a night and dark so hopefully it's something simple like a vacuum hose i missed. Ill keep you posted. Thanks!
Well well. Where to start.
Truck is running better than the day I bought it with 220k miles on it
The ebay IAC I bought came with a plastic plunger that broke off and on top of that the plunger coming out of the IAC was too narrow compared to the okd unit.
Skipped the basics and forgot to compare new to old parts prior to install. Its never idled so smooth!
Thanks guys!
