Identifying a lift
I think someone did a poor job of trying to remove the surface rust. Kinda strange they didn't go ahead and squirt some satin black on the frame and axles like many sellers do. Can't see the nuts and bolts to see how hard it would be to wrench on it to swap on a better lift. Looks reversible. You could probably sell the springs.
IF you can do your own wrenching, and IF you could get it for around $9000ish, you MIGHT end up around $11000ish with a nice 4" lift done right?
I would walk, if you want a super charged one there is one way better fully built 190k arb lockers axles gears bumpers 19k on craigs
That's a whole lot of lift for not much tires...
I would only consider it if it's actually locked and I wanted the supercharger. I'd plan on cutting off that silly lift and putting $1k into a proper, modest lift.
But if I had $10k to put into a rig, I'd just go cheap and put in my own lockers ($1200ish per axle for electronic, I think) and a Toyota or Chevy V8 instead of a supercharger. Obviously that's a lot more work though...
So he paid to have the frame and components sanded about 3 months ago in anticipation of applying POR-15. It does have lockers, and lowish miles, along with a SC. It is a Hawaii car..which are notorious for rust. I really supposed it comes down to the skill and knowledge level of the person that constructed the lift. I assume there is a chance of a driveline issue in the front...are there any other major concerns?
Yes.
RUST. 'nuf said.
