My 80 has barn doors not the tailgate setup. I have been for a while considering replacing the factory inner door trims with aluminium chequerplate or if it's possible to find, something in stainless steel. I know that anything thicker than a couple of mm in any type of steel will add weight whereas aluminium is less heavy. The clip holes formed on the doors can maybe have rivnuts fitted into them and some kind of sheeting secured to those.
Still a work in progress. Got other more important issues (like getting a replacement h150f gearbox!).
I don't have pics yet, but I'm in the process of mounting 9mm marine grade plywood with a beveled on mine. Useful as a cutting board, and it doesn't melt if you put a hot pan on it. Couple of coats of teak oil on it to seal it, then sand it once every year or so to keep it fresh.
Hmm, I have already had a piece of black ABS cut and shaped for replacing mine, but have yet to finish it due to this exact reason. I am thinking a good hybrid solution would be to mount the ABS to the tailgate with countersunk hardware, then to laminate a nice neoprene sheet to the top for a bit of cushion. Should the neoprene get damaged, just remove and add a new piece.
The PO of my 62 did this and 1) it's fugly, 2) you scrape your knees on it getting in and out of the back. I freaking hated it and there is no good way to remove it other than going to town with a grinder, which is not what you want to do with pristine rust-free 60-series parts
I sleep in the back occasionally, and often spend a lot of time on the tailgate hopping in and out of the truck (loading, camping etc), and I personally think carpet is the best material to have there. Who cares if it gets snowed on a few times a year? It'll dry out.
If you want something hard, go with ABS or that cutting board stuff. If you want something easier on the knees but are still averse to carpet, some type of soft rubber (like that marine flooring stuff posted earlier), but for the love of god, DON'T RHINO LINE IT.
