ID the random brackets
Toronto
I cad coated these parts about 15 years ago and forget where they all go...anyone have a look at some of these and say "1 goes here, 2 ges here...." etc? I have a vague memory of 1 on the front of the valve cover holding the fuel and vacuum lines, 3 and 9 as engine pickup points, 5 and 8 on the carb, no idea on the rest?
Thanks!
Good luck with that. Next time take lots of really good pic's. Make a photo log, and edit it to include the information like part name and location. Also helps when asking for help year model market.
#2 looks like a metal gas line clamp near the top of an engine
I believe #8 is throttle cable related.
5,6,and 7 look like the floor interior hold downs for the rear heater wiring....running along the passenger side of the trans tunnel. 3 looks a bit like the steering arm stabilizer bracket that is attached to the frame under the radiator (but that bracket is normally riveted on and not bolted on like this)
#1 is also part of the piping going to the rear heater. it holds down the two hoses, and is bolted to the transmission cover. At least to me that looks like what it is.
#6-7 might be brake line clips that mount on the axel and hold the hard line in place.
1. Valve cover mounted bracket for air injection hose/pcv hose.
2. Idk right now
3. Idk right now
4. Idk right now
5. Fuel cut solenoid bracket that mounts to rear of valve cover
6. Brake Line clamp
7. Brake Line Clamp
8. Fuel line bracket, lower front of engine by fuel pump.
9. Rear engine lifting hook.
