Icon Rebound Pro wheels
New Jersey
Website
www.sdsysdesign.com
Has anyone run the Icon Rebound Pro wheels on an 80?
My current wheels are 16x8 with a 4" BS with weld-on beadlocks with SAM-27 Swampers (36x13).
I get just a bit of rubbing at full stuff, which doesn't bother me. I'm concerned about the 4.75" BS on the Icons.
I happen to have just put a set on mine. I guess they don’t list them as fitting the Landcruiser 80 series because the center cap won’t fit.
I think the wheels fit well.
I haven’t really taken pictures to show the wheels. These are just some random things I found on the phone. Part # 21817858347TT
I'll probably stick with 36s of some sort, but might have to go with 37s depending on available tire choices.
Do the 37s rub on full stuff?
I also tend to run low pressure in the rocks. With the current Swampers, I'm usually down around 10 or 11psi. Possibly a bit lower depending on the terrain.
Good beadlocks are important.
They do. I have added drop bumpstops front and rear and still require a bit of wheel well trimming/massaging.
And keep in mind the tires are BFG KM3 37s, which actually measure out around 35.5”.
Oh well. That's not going to work for me. The tires I'm looking at are true 36 or 37.
I found that a 4" backspace works really well.
Just not interested in spending 5 or 600 on a wheel. Might have to stick with the rims I have.
I got lucky and stumbled onto these on Marketplace.
I did buy one new spare wheel and it was $325 from Summit.
Unfortunately, to get a 4" BS true beadlock, I haven't found any wheel under $500.
My current Swampers are from 2017 and I've dragged them all over the US, so they owe me nothing more. Like everything else, tires have gotten very expensive. Not quite ready to drop $4K for rims and tires at this point.
Thanks for the feedback. I appreciate it.
I've been happy with the Icons. Gotta remind the tire monkeys at the shop about those bead retention bolts tho. I usually mount/balance my own tires because of that. If you don't have access to the equipment- it's on you to remember to remind the guys when it comes time for new tires.
I run mine 0 offset with a 1.25" spacer and I'm pretty happy with it. I spent a lot of time and money setting up my bump stops to keep the tires off the flares- and keep the wheel spacers in place. Depending on your lift/tire combo you may need more than just the 'standard' bump stop spacers. Without the spacers they'll tuck in a bit more (like the OEM wheels) but that just makes the rubbing happen on the inside with 37s...
All those retaining bolts become possible leak points.
That’s a no go for me 🤷‍♂️
I'm going to finish out this wheeling season with my current setup and pick up some new rubber over the winter. I'll probably stick with my current "home made" beadlocks because they really work well and the tires stuff without having to limit uptravel. Again, a bit of rubbing in the rear inside at full stuff doesn't bother me.
As a wiser man than I once said, "If your tires don't rub, you can fit bigger tires."
