IBS Dual Battery install question
For those special few :wrench::beer::wrench: who have done this mod, did you incorporate the Relay Booster Module? Christo's site says that it is required, but I can't figure out where.
Hopefully someone can answer this before Monday, 'cause I've got a perfect weekend to play with the cruiser!
:cheers:
Nevermind, just found the schematic online. Interesting function added with this device.
Too late, but I did install the booster Module
What is the IBS system?.
Ive been finnishing mine off this weekend and running 2awg battery cable from the second battery through the cab and out to the rear bar to an anderson plug to power the camper im building.
I ran it through the cab so i can ron my fridge off it and run an inverter and power outlets in the rear storage draws.
Scroll down on the right to see IBS:
Slee - Battery Related Products
I had one from a previous rig that I transplanted into the 200, along with the SLEE bracket. Just bolted the relay box to the firewall, sandwiched its mounting wing between a bolt and some piece of technowizardry. Double-stuck the display/controller along the side of the center console.
