so my pig and i have only known each other for less than a year.
we have been having a battle of wills most of that time. i'm stumped, the bitch absolutely refuses to run. but then it does... then it doesn't...
so with winter coming i am on the rampage to figure this out. so a guy tells me " to know if you have a vacume leak choke the carb with your hand, if the revs go up you have a leak.
sure enough, vacume leak. so i check the nuts on the carb, all tight. i check the bolts for the intake exhaust manifold, and find 4 lose ones. start it up, she runs better but won't idle without the choke.
but, i'm feeling lucky, so i take it for a little drive...
seems to run great. more power than previously and responsive. i make it to the highway...
just get up to 50 mph. bam, totally shuts down. sputters with pumping the peddle.
i am realizing i'm going to be dead on a major traffic artery. opt to hit the curb at 30kmph and cross on to a secondary road, coasting with no power. i get to the edge of the road where i can safely pull off, start looking for the cause.
realize that my site glass on the carb is empty. having been through this (i have a compressor in the back, volume tank full of air) blow out the lines to the tank and reconnect them. try to start it again, nothing not even a sputter with a full float bowl.
start thinking it might be spark, so i pull a plug and try to see if it gives a spark. can't see s*** in the middle of the day, but i try again to start. nothing.
...i think to pull off the dist. cap(which i have never removed, embarassing) contacts are so corroded. no wonder the thing won't fire.
so i clean everything up as best i can.
RAR, RAR, RAR, VROOM
so, not feeling as lucky i drive with tail between legs to a friend's house. screw around with fj40 i am also playing with...
that's another story.
drive home. Celebrate
so what do i take from this?
i have a pig with multiple compound issues. at least dirty tank, vacume leaks, and in need of new cap and rotor, wires...
though some how i feel i am getting closer to getting this thing licked.
sometimes i wonder why i screw around with cruiser...
but doesn't it make every day an adventure? must have looked awesome when my truck hit that curb at 30 km's...
anyway, just sharing.
the pig saga continues.
