I updated my alignment readout
Van
Pls comment on my readout
I know its off, but how bad is it?
Thanks again
Which part has you concerned? I wish my rig had your castor numbers.
How bad im off.
your not, the specs are in the green or close enough so their good. its a solid axle so there will be minimal adjustments that can be made for camber. the thrust angle is soooooo minimal youll never notice it and it will never cause any sort of issue
Is this a stock truck?
@Delta VS stock truck alert
John, its not often we get alignment data on stock trucks. No cause for alarm.
@John copello would you be willing to take a few measurements of your ride height?
@Delta VS can you link to the thread or the form? I searched but did not locate it.
before you get all giddy about getting some stock numbers you might want to realize that the springs in this truck are likely 20+ years old and not representative of a stock truck that just rolled off the assembly line.
Front and rear aproxx 19 3/4" center of hub to lowest lip of fender
Awesome! Thanks John!
Wait... they stopped making this truck 10 yrs ago!? No one told me!! This topic is always a fun one. :love:
@landtank, Dont need to tell you that 'rolled off the lot' height isn't necessary. You just need castor, target castor, height, and a calculator.
and given for more than a decade.
base height of 20.5" (hub to flare), caster change of 1.74* per inch of lift and factory target of 3* +/- 1*.
so with his measurement of 19 3/4" that would result in a caster increase of 1.305*
so 3* + 1.305* = 4.305*
seems pretty close to his readings to me.
pretty close
Yes.
And the hub to flare measurement is sometimes given as 20" and sometimes 20.5".
Castor changes are nonlinear but yes, 1.74* is a good rule of thumb.
I appreciate the information thats out there.
