Old Nick
GOLD Star
I’ve got several tubes on the shelf. Sounds like a plan.I used regular ol Toyota FIPG.
Black RTV is still working fine on mine. If you take it apart carefully, the slip fit of the top is doing most of the work. You're just providing something to fill the void.anyone foresee any issue with using this black seam sealer on the can? I've just opened a tube of this to seal one fender.. so it would be good to find another use for it haha:
TEROSON® MS 9320 - https://www.henkel-adhesives.com/ng/en/product/flexible-sealants/teroson_ms_93200.html
https://datasheets.tdx.henkel.com/TEROSON-MS-9320-en_GL.pdf
Datasheet says it's resistant to petrol and bonds well to steel and says its suitable for the engine compartment
Chemical resistance
resistant to light, PVC plasticizers and (short term)to petrol
In service temperature range, °C -40 to 90 - short exposure (up to 3 hrs), °C 130
It is a semi flexible finish though, not a rock hard finish, but it should just expand and contract a little with heat without cracking or letting go.
Sweet!Black RTV is still working fine on mine. If you take it apart carefully, the slip fit of the top is doing most of the work. You're just providing something to fill the void.
Been through a couple of summers now with no more pressurized tank, no fuel smell and no signs of the top popping lose despite using sealant instead of something more rigid. I did remove and reinstall it a while back because I needed to work around it for a wiring project. It looked just like the day I rebuilt it.
I used my disc sander to remove the bare minimum on the outside edge. If you look at Phil's third pic on the first post, you can see roughly what you're going for. The actual top is sort of recessed, so you take the very edge off, but the top fits down into the body a little bit.Sweet!
Did you need to grind the lid off or just pry around it?
Did @LandCruiserPhil ’sI used my disc sander to remove the bare minimum on the outside edge. If you look at Phil's third pic on the first post, you can see roughly what you're going for. The actual top is sort of recessed, so you take the very edge off, but the top fits down into the body a little bit.
