I own one now!
Milwaukee, WI and Louisville, KY
Well guys, I'm finally one of you all. I bought the 91 LC I was going to look at tonight. I think I got a pretty good deal. :D
I will post pictures tomorrow.
One item that needs attention. One of the BIRf's (drivers side)need to be replaced. It's leaking some grease and from research on here it looks like it needs to be done. The other one looks good. Is it common for these to go out at different times?
How much should I expect to spend to have this replaced? I saw the prices for the parts online. But the labor is the variable. If I had the tools this would be a cool project but that will have to wait.
Anyone have a good shop in the Milwaukee area?
Thanks!
Hey, congrat's!!
Take a little time and read up on the front axle issues. The birfield doesn't automatically need to be replaced; it's an inner axle seal that's leaking, and how many components you choose to replace can vary. Educate yourself and then decide on your course of action.
Welcome again,
Curtis
Awesome! You made the right choice.... Welcome :flipoff2:
And as you may already know, we are pic whores, so make it snappy! (no pun intended)
Hey, congrat's!!
Welcome again,
Curtis
Hopefully thats all thats wrong. Just need to find a honest mechanic. Ha. Good luck right....
I will post pictures tomorrow when the sun shows off the ride a little better!
Typical shop is $1300. make sure he at least uses Toyota inner axle seals, the aftermarkets fail easy. Might save you some money to call cruiserdan (Toyota parts manager) tell him your from Mud and you need the front axle kit. I would get new trunion bearings and races, but try and re-use your wheel bearings.
If you follow the FAQ write-up on this front axle job, you could do it yourself for about $200 saving $1100 for some other mods.
First time it will take two long days and maybe someone close by will come walk you through it.
Labor is the killer as Romer mentions. If your mechanic is looking for a lot of $$ you might want to consider looking for a Toyota club in your area and see if anyone there is looking for some side $$. Folks that have done these before and are good at this can get it done in about 1/2 a day (say 4-6 hours).
You will often end up with a better job overall and can have things like swapping the birfs side to side done that your typical dealer/mechanic isn't going to do. And, people that wrench on their own rigs tend to take more pride in their work, doing the extra things and not taking short cuts.
Often they will let you help so you can cut down the overall time and learn as you go as well :cool:. This is the approach I took and it was a wonderful experience. It was amazing to watch a true pro work on a rig. It is also enjoyable to work on a rig with someone that knows what they are doing.
Pictures
So I just gave her a quick bath, then proceeded to drive around Milwaukee like an oil sheik.
She's running good, other than the BRFL issue which I hope to get resolved sooner rather than later.
To start I am just going to do a couple easy mods.
Yamika Roof Rack and cargo box.
Slee Bumper. I really like the ShortBus model.
New tires.
Snorkel. I know I don't need it at all, but they look so cool.
JP
***Update***
Help. I can't load the photos??
Thanks Tiger
Hope this one turns out.
Looks clean.
I like the color.
Welcome, Im new as well.
Welcome!:flipoff2:
JP
***Update***
Someone can correct me if I am wrong but I don't think the snorkel is necessarily considered an "easy" mod...Not like a CDL button install or similar would be. I've never installed one but from the pictures I've seen cutting that hole would freak me out pretty good :eek:
As for pictures, using photobucket or similar is pretty slick (as long as you never change the "path"). If you use MUD to host a pic via the "manage attachments" button when posting a thread, make sure you size them 800x800 or smaller and under 120kbs (IIRC) before trying to attach them. Oh, and don't forget to click "upload" after you have browsed to find the pics :)
With the template if you just look everything over carefully and have the proper tools, its fairly easy and about two hours start to finish first time tops.
The key is the right hole saw, the spring punch to make sure the drill bits have a good place to start and a step drill bit. Follow the template and use tape to protect the paint.
Here is a good write-up on an install. It's the one I followed, but I still had to do the lip for the new snorkel at the antenna
http://george4wd.taskled.com/snorkel.html
That page makes it not look that tough and I think I have or have access to the needed tools.
congratulations and welcome. you'll be an addict soon! :cheers::beer:
