I need some help installing LED tail lights...
If you don't use the resistors , the longer the turn signal is in the on position - the faster they will flash , unless it already has an electronic flasher unit installed . Coolerman has the electronic flashers for us , as well as the stub harness to install it correctly .
Sarge
Thanks for the heads up. I was looking for an excuse to rewire them again as I'm not crazy happy with my first attempt. Guess I will graft those into the process.
A few Narva LEDs arrived today.
J
in the description of each there it tells you if it clicks or not.
Got my new Narvas from Jason and I also bought some new tail light guards off the classifieds. The lights don't fit in the guards. What did you guys do to make them work?
Nothing in my case - just ended up not using the guards. Sorry, probably not very helpful.
