I need opinions
Philadelphia, PA
Both my shocks and springs are worn at this point on my 1980 FJ-40. It is my daily driver and everything is stock, including no lift and original size tires.
My question is, I neither have the time or money to put in a completely new suspension at his point - is it worth it and will it help to just put on new shocks?
I am really looking to help it on the road bumps. Normal driving conditions are fine for now, except for heavy bumps and such.
as a general rule, shocks just control the rebound of the springs. to use shocks for height is putting a lot of extra stress on the shocks mounting locations.
I am not trying to add any lift, just soften the ride a little until I can get my springs also.
New shocks will improve the ride for sure. But if you want lift springs later, new stock length shocks might be too short. If you can decide now what springs you will be buying in the future you're good as gold. Not something I could ever do, though.
Are you even planning on lifting it?
If not just get the shocks now. Then when you have more time get the new spings (stock ride hight). The new shocks may have to worka little over time with the old springs for a little while but should be fine. And if all you are doing is swapping in a new set of stockers then it shouldnt take you but a Saturday to swap all 4.
Shock will generaly firm up the ride. like stated above, shocks controll the movement of the springs. with worn out shocks the truck will just bounce. to test if your shocks are ok bounce the truck up down on the front (or rear) of the truck. If the shocks are ok it should bounce about once and then stop. If the shocks are dead it will continue to bounce a few more times.
When I go for new springs they will be stock lift. Sounds like new shocks will help for now. thanks
