- Thread starter
- #21
That's how my fsm said to do it but on her guys said to put the gear 15° ahead of that mark because the gear makes it rotate.Line up the line on the pully at tdc/0
There is a protruding mark on the gear. Line it up with the mark/line on the shaft of the distributor. Insert the distributor so that the hold down bolt is in the middle of the adjustment slot.
If it doesn't start. Remove and rotate crank 360 degrees and try again.
Oh well, I needed an alignment anyway...
