i have a question about this rig
this is my rig and im lookin to put an exhaust on it... but im scared to spend alot of money and it not sound good.
any one have any suggestions? what about the cheap exhaust from auto zone that supposely sound the same as the flowmaster...?
heres my ride
You gotta understand...other than color, ride height, accessories and background scenery... it looks JUST like everyone else's truck out there. So you have really given us nothing to work with to try and help. And the first thing you are going to get otherwise is a "have you tried Search?"
So with that... have you tried Search?
daaaaaaaaaaaaaaaaaaaaamn teachey thats a sharp rig!!!!!! ;) check out my post and other peeps too. I have been searching just exhaust in 80s and came up w/ a wealth of info and turned out not all so necessary as i went to a local exhaust guy and told him what i wanted and let him fab it up with what hes got. If you are going to order parts ahead of time and let someone weld it up then look through all the post and you can collect part #'s and just call summit.
re cheap exhaust from autozone: NO
regarding things that sound like flowmaster: NO
regarding both NOWAY
general concesus is stock (or bosal replacement) is closest to stock and no extra noise.
Boral makes one but the kit sucks and lining things up is hard, better to get borla peices put together for you
Id go to a local shop and tell him what you want............. stick w/ 2.5'' pipe and ask for a similarly spec' muffler as this is where most of you noise input comes from. Tell him you dont want any hwy drone or excess acceleration noise, just something like it came w/. I have a friend that went and got two new cats and one tubo muffler installed for 250. He had the option of putting a muffler like came on it back on, or one like what was existing there (evidiently PO had changed muffler b4)
i like to look for the lil independents and a referral goes a long way in my case, but even some folks have had luck the meinekie like shops.
g'luck
https://forum.ih8mud.com/80-series-tech/223533-new-3-cat-back-exhaust.html
IH8MUD™ Forums - Search Results
oh yeah, why are you looking to change it out?
If all is functional then you might not be "allowed" to change cat or may just chose to go 2.5 from cat over frame rail to nice muffler and out of harms way and spend less than 200. There are some great websites w/ soundbites of diff mufflers but not for our rig so i didnt bother. Ill be adding a glasspack to tone mine down after muffler, and that would always be an option for yo if you did not like the first muffler attempt.
Any time you replace a stock muffler you run a high risk of loosing that stock sound.:idea: If you like the sound of the Flowmaster the only way to get it is buy a Flowmaster. FWIW, the Flowmaster triple chamber on my jeep is not quiet. If you hear a Flowmaster you like on something other than an 80, good luck getting the same sound.
So here is what I did:
I got three quotes to replace the cats, O2 sensors and building a system over the frame. I choose the least expensive one using a Magnaflow muffler. The workmanship was excellent. The sound was horrible. It had a drone on the highway that was very bad. We added a glass pack resonator and life is good. I really like the system now. All told I invested @ $650 and I am very happy.
Just make sure you ask your muffler shop if they will be able to modify the system if it is too loud.
:cheers:
I threw a summit glasspack on, and i think it sounds great. Its loud, but not annoying at freeway speed. It's definitely loud though. At around 3k RPM it has this cackle too it. I love it.
na haha teachey is my last name and that is the ome j's with 305 m/ts... im putting the slee coil spacer on the front.. i have a friend that put glass packs on his truck and they do sound good. im not sure what i want to do yet because i dont have a lot of money.
can i get dual glass packs? or would that not sound good you think?
"Sound good" is a subjective term. What sounds good to you will drive others crazy. As others have recommended, select wisely lest you get something that is too loud.
My recommendation is to have them turn the cats when they do the muffler. I didn't and I regret it. A friend did and his now has much better clearance around the cats.
-B-
I have a flowmaster 60 series and am happy with it. It's a less expensive than stock
I have a flowmaster it tucks up real neat and was not too spendy, but don't fix whats not broken?!!
