HZJ73 vs BJ74?
Orygun
I've been thinking of giving my '14 BMW X1 to my kids so that they will have a more dependable second car (they currently have a '11 Audi Q5 that is a money pit).
I have been thinking about a Land Cruiser to replace the X1 as a "daily driver" (or more accurately, a bi-monthly driver as I only drive anywhere maybe twice a month).
Keeping my eyes open online, I have narrowed down the choices to a '92 HZJ73 ZX and 132K km and a '89 BJ74 and 9K km (yes, less than 10K km!) w/13BT engine. Both are of course JDM imports, both have diesel engines and manual transmission. One (the ZX is local) and the other (BJ74) is about 1400 miles away. The BJ74 looks almost pristine (but no photos of the engine compartment yet) and has a factory PTO winch (the 73 doesn't have a winch).
I've done some googling on these, am still a bit confused regarding the 73 vs 74 configurations. Other than that, I am leaning towards the very low mileage 74 and its 13BT, but OTOH the 73 has the less complicated (more reliable?) HZ1. As far as I can tell, besides the trim, the 73 & 74 have the same drivetrain (except for the engines) & suspension. The 74 is $5K less than the 73.
One concern I have about the low mileage 74 is that obviously it has probably been sitting with very little use for 37 years. Not concerned about tires, but the rest of it? As far as I can see, it doesn't look like any hoses underneath (e.g.fuel hoses) are rotting, but might be rotten inside?
I am not in a rush to get either one (I've got some personal stuff going on I need to attend to first) - hell, they might be sold by the time I am ready to buy - but I am interested in your thoughts on these vehicles.
just be prepared to tear into at least half of everything... seriously they are of that age
Either one? Makes sense. I am used to it.
BTW - I noticed the 74 has manual locking hubs. I was under the impression that the 73 & 74 of this era had auto axle disconnect or hubs.
Electric locking hubs were introduced in 1990, so the BJ74 would have manual hubs while most JDM HZJ73's will have electric hubs.
At that age plan to replace a lot of hoses, belts, gaskets, etc regardless of mileage. Parts age out just as much as they wear out.
All other considerations aside, I'd be inclined toward the 73 rather than the 74 due to parts availability. The B-series engines have been out of production for around 30 years, while the 1HZ is still in production to this day. The rest of the vehicle will be largely similar.
Makes sense as the 73 has electric windows, etc.
That said, I prefer everything to be manual, minimal electronics. I would windup converting to manual hubs if possible (I intend to do that on my HIlux and my Dodge).
I wouldn't worry much about the 13BT engine itself, not the core parts, as it has so few miles on it, and I would not be putting very many miles on it myself (maybe a few thousand a year). OTOH, there would be worry about some accessory parts (pulleys, etc.) - and possibly the turbo (that might be the main worry if I was in the backcountry). I was reading somewhere that the B engines are used in other machines (e.g., fork lifts, etc.) so some parts are out there.
It would be kewl to have a really low mileage 74.
OTOH - the 1HZ is a simpler engine - no turbo. On the other other hand, the 13BT has timing gears, where the 1HZ has a timing belt?
Sometimes I get to thinking what I would do if my 13bt blew up. I installed a Gturbo about 10 years ago and it runs without a wastegate controller. I drive it to the Rockies every 2 years or so and it does just fine, though sometimes painfully underpowered. 33” tires maybe not the best choice. The pto winch works well and does the job.
HZJ73, then when you get sick of how slow it is, you've got an easy swap to a 1HD-###
As someone told me once, disuse is harder on a vehicle than misuse, I wouldn't buy the BJ74 unless I planned to go though everything mechanical; it must have been sitting for a significant portion of it's life which doesn't do a vehicle any favours.
I can't speak for the BJ-74, but I do own an HZJ-73 and it is a real pleasure to drive. About the only time I have issues with the power is when I have to pull out on a busy road and get up to speed. Otherwise, normal takeoffs and cruising speed are fine. My truck will roll down the road 70mph easy and it rides really nice even though it is on leaf springs. I have 34" tires on mine and the "rubber regear" is perfect because that 1HZ has plenty of get up and go torque to overcome the tire size- it just makes zero horsepower so even though it can rev high for a diesel, not much happens. When I have to get into it, it pulls way betting kind of lugging it. That makes heat, I know, but it is only for a few seconds to get it moving. That slightly longer wheelbase is a game changer for ride too. Of course you will have the same suspension on both so all good there.
@FJBen rocks a 13bt in his truck. Maybe he can chime in. I thought it sounded pretty good.
I had a BJ71 & BJ74, both with the 13BT, and thought the engine was great but it was also 10-15 years ago. I’d choose the 1HZ all day.
I will say, the 13BT is a great engine. Runs good, handles pretty good boost without the worries the 1HZ has and is overall a reliable engine.
It's really just about the parts availability for me. I guess it really depends on conditions of both.
A clean, maintained good running 13bt with low miles is a great cruiser and a better choice than a rough or unmaintained 1HZ.
HOwever, at 9,000kms, thats very interesting on ANY engine of that age. I'd have to know the specifics on why the low usage because not using an engine regularly can cause all sorts of things to fix once you start using it.
The timing belt is literally the easiest one on the planet to change. Literally less than 20 pieces of hardware.
And no Toyota timing belt engines are bad. They are all **exceptionally** good.
……. Except for the 3VZ-FE….
Good to know. I've only had one Toyota with a timing belt. Bought in 2002 and still own it. It's a '90 4Runner with the 3VZE. 🤷‍♂️ 🤣
My nod towards the 1HZ was simply based on parts availability. I had good luck with my 13BT’s.
1HZ is pretty slow, but enough power to get you around (unless you live at altitude like I do, then you question your decisions). 1HZ has full parts support, the engine is still made, very smooth, super easy to drive. Drives like a slow gas engine. 13BT is like a baby cummins 4BT. Rough around the edges, starts hard in the cold, but it does it. You can easily shove more boost into it and get some power, 13BT also gets great fuel economy (I got 22-25MPG on 35s). You can turbo a 1HZ but you've gotta be careful. Fuel economy on the 1HZ is meh, I can eek 20mpg out of it on 35s with t case gear reduction if I just embrace the slowness on the hills. I currently own an HZJ73 and I love it despite having what I think is injection pump problems. Up until this issues it's been 100% reliable and I drove it almost every day. 1HZ is way easier to work on than the 13BT. Gonna figure this fueling issue out and get back to driving it every day. I've owned both, made the mistake of selling the BJ74, then a tree fell on it just as I was about to buy it back. My current whip, that I intend to be buried in, is a nice 1997 HZJ73 that I've built up well, but it's higher mileage than the BJ74 and I've had to do a little more maintenance. I think I've seen that BJ74 you're talking about online and that would be AWESOME, I wouldn't hesitate but you'll have to replace everything that is made of rubber and holds fluids, so be ready for the first 6 months of ownership to be kind of a headache. After you get through it throwing up on itself it'll run for a long time. Parts for the 13BT are hard to scavenge, that engine hasn't been made for a long time. Really depends on what you want, if rough around the edges and kinda loud diesel-y things are your jam scoop up the BJ74. If you want something a little easier to live with, that's quiet and easy to drive without putting much thought into it (other than approaching a steep grade), then the HZJ73 is the way to go. Both have cool interiors, later model HZJ73s have a little nicer interior but nothing that makes too much of a difference.
I was watching various vids on 73s & 74s, and noticed that the engine layout/etc. in the engine compartment of the 73 with a 1HZ seemed noticeably simpler than that of the 13BT.
They had the infamous head gasket recall for years. Once the HG recall is done they are indeed a great engine…. Utterly gutless and underpowered.
