whine?
As in the pump making a noise or the belt slipping on the small diameter pulley?
pure and real whine .. if you have time check it here ..
YouTube - Buena Vista 2011 Parte 1
whine?
I sheered an ARP off recently... I really think I should do the 6 shooters myself but they co$t $o much $$!
on topic, let us know how it keeps up after drilling it.
I used these:
6 Stud Knuckle Conversion Blocks | 4×4 Labs
and used their 6 stud high steer arms. Everything worked out great.
Their kit is more than TG's with new knuckles. But if you mixed the two it would be cheaper... I know a lot of people bash on TG but the things I have gotten from them I have had no issues. this includes high steer, knuckle kit, and ram kit for my white 60. And my truggy has a TG ram.
The 6 studs will have to wait for now either way, but thanks for the link! I like that idea for sure.
I hear you. I have a soft spot for my factory knuckles since they were the large pattern already. I've had good luck with 4x4 labs.
You could make those blocks pretty easily, btw.
You can shim the pressure valve on your saginaw pump to produce more fluid flow through your system. It helps out a little bit for a better reaction time but once again it comes down to the amount of fluid volume your entire system can handle.
powersteering
I modded my pump as described on this site. Now just gotta lengthen my pitman arm and I hope to be good to crawl.
do you still drive your rig on the street any?
I used these:
When I get done with it, the only possible way that the pitman will break is by slamming into a boulder with the weight of the vehicle on top of it.
i've been real happy with TG products myself including 6-shooters and their ram
i try to let everyone know about this- you can save a signifigant amount of money on trail-gear products by going through one of several TG vendors on pirate in the misc. vendors section....usually will give you a 10-15% discount off TG's price and free shipping
well that's not what i was getting at lol....
if you ARE pretty much done with driving your 40 on the road then i am here to tell you from personal experience that can fight and modify all you want but you will probably never be happy with that hydro-assist setup for serious rockcrawling.....it's ok with small tires but with big tires aired down low for crawling its just not good enough.....the cool thing is there are tons of people that will buy that whole setup from you and then you can do full hydro for about the same cost if your peice it together yourself
