Hy-Steer/Crossover Steering Question
Will Van
GOLD Star
Austin, TX
I am looking at a 40 series (to purchase) that has a SOA lift and a High-Steer/Crossover steering setup. I'm not very familiar with these setups. Could someone give me advice on what to look for to ensure it has been modified properly?
Does this High-Steer setup look correct? When you go to High-Steer, are you supposed to delete the steering dampener from the frame to the pitman arm? Is the tie rod supposed to be mounted below the leaf springs?
Hard to make the call from one, grainy pic ( think grassy knoll in Dallas!) but I’m pretty sure that setup is not sano. Under compression, the left spring will be in the plane of motion of the pitman arm, potentially locking out your steering.
Might want to get a close up of the double arm on the passenger side as well.
Edit: get a better shot of the steering box mount while your at it.
Yeah that's looking a little sketchy.
I think both draglinks should be over the leaf springs...
Looks like a Aqalu arm on pass side. This is the way lots of people did it before true high steer arms came out.
Here's my hy-steer as best I could get. You can see the tie rod above and in back and I got a picture of the knuckle studs as well.
2012105
2012106
2012107
2012111
