Build Hundo Family Truckster
While I was doing the deflector I thought I would try an experiment with some plastidip on the scratched hood. It was a failure but I learned some good lessons. I
Don't plastidip if its 90 degrees out. (I was in the shade)
Plastidip works much better with a vertical project than a horizontal one
Don't try to do such a large area with it as it drys to fast
Hope your can of dip doesn't start dripping on your project, ugh
Before:
2019849
During:
2019858
After:
2019861
I think I'll pay to have it wrapped in that section.
These things are very high quality. Thanks to Jason at Trail Tailor, quick turnaround and excellent communication.
Edit: I did have some contact with the pinch weld at the front and had to pry that back a bit as well as angle the slider down with a washer behind the top. You can see its very close at the front here.
2025229
2025230
2025231
The front one is held on by 3 screws on the back of the grill, just pull, smooth, clean and dip. The rears you blue tape tape all the way around. Spray 3-4 coats and let dry, I usually wait an hour between coats. Peel off the tape, then using a wood skewer or toothpicks carefully peel off all of the unwanted dip.
It takes a bit of practice but you can easily pull it off and redo if need be. The emblems/letters back edge will basically cut the plastidip when you peel it off. T
Here is one I got a little hasty with and peeled off some, so I am redoing it.
2025772
Prep:
2025773
I don't generally worry about over spray with Plastidip, if it happens you can just rub it off with a microfiber rag. I'll get some pics of how I peel it when dry.
Hitting Yankee Boy Basin Tomorrow. Trying to lower the profile and fit the truckster in the garage. In the process I realized the jack mechanism needed to be put in the recovery bag. Reduced the overall weight on the OEM rack by a good 15 lbs as well.
Apparently I always wave at the camera when take pictures like this, SMH.
2027743
2027745
2027746
2027747
Heater T's are the next order of business. I thought I was going to be fishing plastic out of the hoses when they looked like this.
2033370
But in all actuality they looked like this. Old on top, new on the bottom. looks to me like they had been done somewhat recently, at least I will have a trail spare or 2.
2033371
Nice towel placement, SMH
2033376
One trick on this that I found useful was to use some stress mats and actually lay on my belly over them to access the hose clamps easier. Much easier than trying to access from the fender IMO.
2033378
Found this under the engine cover. Apparently the P/O had a problem at some point?
2033379
We just missed one another in Ouray! I was there 7/12-13.
Really digging your Cruiser and the small changes 👍
Rear Back up Camera installed using the OEM nav unit and the Naviks module. Thread for reference:
Red = ACC
Back = Ground
Brown = Reverse Switch
license plate light with predictive tracks.
