Build Hundo Family Truckster
Taking my boon-docking game up a notch. Predator 3500 generator/inverter. Thing is really quiet compared to the 15 year old 2500w unit we had on the fifth wheel, and it can power A/C, outlets and the microwave.
Maiden voyage with the truck and hybrid trailer. Cruiser did awesome pulling 4500 lbs. Took it up to about 9500 ft on the Middle Mountain road. One of the airlift bags shot off the line so I need to get a new compression fitting, other than that everything worked great.
Enough gear and supplies to boon-dock for 3 nights plus.
Bought a gear and 4 bike rack for the back of the trailer. I thought I would modify it to be closer to the trailer bumper, instead of hanging like a wet noodle, at the same time making it fit the cruiser with the spare tire.
Before
Like butta'
after, cut off a useless 7 inches.
A/C drain rerouted. The L tube is pretty tough to get in there, I would put a little window cleaner on it prior. I routed it pretty much straight down and zip tied it to the sway bar itself.
The folks at Cruiser Garage give you the good Zip Ties
Is your driveway level? Mine has a slight slope L to R so I can't use my garage door as a guide, haha
Asfir skid showed up today. So much faster than what I expected from Israel. A couple notes about going this direction. I am not wanting to really lift and go bigger right now as I want to be able to keep it in the garage. I'm sure I will at some point so a newer low profile rack will be in order, prior to doing that. Hence the reason slider and skids are my priority. I don't really do too much rock crawling anymore so I felt aluminum was going to be fine.
And my new best friend, this thing rocks so far.
