Hum/Vibration associated with clunk/ping?
Broken exhaust mount?
Exhaust mounts are all 2-3 months old. Replaced when I did my O2 sensors. It's more solid of a vibration than exhaust.
Finally had time to check the U-joints. Didn't notice and side to side play. Was able to move the drive shaft about 1/4" in and out (forward and backwards). Pumped grease in to them (at least I think I did, I freaking hate grease guns, are they all so finicky?). Drove it and it appears to be gone. Maybe I am imagining it is gone, not sure. Will drive again in the morning and see...
... Was able to move the drive shaft about 1/4" in and out (forward and backwards). ...
Please expand on this a bit, what moved? Both ends of the drive shaft should be solidly mounted, shouldn't be able to move them?
I grabbed the drive shaft coming out of the transfer case (correct?) going to the rear and it felt like it moved a 1/4". I'll have to check it again in the morning. Maybe it was just my rubber glove slipping on the oil splattered on the drive shaft for my leaking 3FE.
Too much grease in the slip yokes? Read this really quick......just a thought (but do answer @Tools R Us 's question, he knows his stuff).
I don't think it's a matter of too much grease in the slip yokes.
I tried to explain the "movement" as best I could. I will have to double check it in the morning and post my findings.
Vibration is still there. Tried to check the play but couldn't get it to move. Had to go to work so will hopefully get a chance to check when I get home again. Otherwise I have all day tomorrow.
To check drive line stuff, the stress needs to be off, chock tires, shift the transfer to N.
Oops. Didn't do that! Will check it tonight! Is there a method I should check it? Like am I supposed to use a pry bar or just grab it and pull? (@NLXTACY there is joke served on a platter for you)
Got her up on jack stands. When I rotate the front wheels there is a slight hesitation before the drive shaft moves. Maybe 1/4 turn or so. Letting her cool down before I roll underneath her to check for play in the shaft.
Ok. I checked the front driveshaft and rear drive shaft u joints for play. None. No movement whatsoever. Side to side. Front to back. Nothing. Grabbed the shaft and jerked on it and it didn't move. Had the truck on four stands, in neutral. Nothing. While I was under I checked the exhaust as that was mentioned before. I did find that the two "Cat shields" (I believe this is what they are) were loose. One clamp is missing, the other is there but loose and rusted. I am looking for a couple of clamps in my stuff to tighten them up. Don't think this is the vibration.
Wheel bearings? I didn't want to dig in to this but I guess I will have to. I'm going to order new bearings tomorrow to have in case...
Vibration on the transfer case shifter. I guess that means the U joint...
Now, which one? Or do I replace both? Or are there 4?
Finally pulled the front driveshaft and the rear u joint of the front drive shaft is fubar. Seals are out of it.
Was this the problem?
I have a vibration but it’s only under certain conditions.
Under WOT I have no vibration, but half throttle it’s there. When I let off the gas pedal I hear a “PANK” sound.
Possibly drive flanges on the front hub, but could also be uni joints.
Uni joints will typically growl a little more on deceleration.
Greasing u joints will sometimes relieve the vibration temporarily.
IMO Best way to check uni joints is remove driveshaft and check that the uni joints rotate freely in all directions, if not, they are toast.
... When I let off the gas pedal I hear a “PANK” sound.
That is often dry slip splines. Chock the wheels, shift the transfer to N, inspect the u-joints for play and grease them and the slip splines.
