Hubs
San Antonio TX
On the mini axle I picked up yesterday it has the stock Aisin hubs, on my 40 axle I have Warn hubs, will they interchange? If so, which ones should I use and why?
Thanks
If you have the stock 73 axle in yours, then the mini hubs will not work.
If you have newer axle or birfs then they will.
The Aisan hubs work with the mini birfs. The Aisans are stronger and don't stick out as far as the Warns do. IIRC, the Aisans are all steel, no aluminum. Easy choice.
GL
Ed
Poser said:
Hubs contian the wheel bearings...
Lockouts isolate the hub from the axle shaft....
I meant LOCKOUT hubs. I think he was asking whether he could use the Aisin LOCKOUT hubs in place of the WARN LOCKOUT hubs:D
ed
I went through this a few months ago. NOS Aisin hubs are available from several sources - but very expensive. I got a used set off ebay for minimal $ only to find out that they did'nt fit. Later learned that there's a difference between hubs from earlier solid axles and later IFS axles. Grabbed another set for solid axles, tore downa and rebuilt, and have assembled on a set of 30-spline Longfields.
Nicely done!!! AND, where would we be without Poser correcting us all the time?
That's even nicer than my recent retro fit, I wen tall the way with new, new and new, rotors bearing calipers but bought a set a superwinch hubs for 90 bucks they are nicer than the warns in that they have a lower profile. My Warn hubs have probably been on since 78' and they look it. The rebuild kit was almost 30 bucks by the time it went to my door step so I said WTF replace them. I really wanted Asians but couldn't locate a set in time.
I will eventually find a nice set WHERE DID YOU GETTHOSE HUBS?? how much$, I wan to keep those superwitches for a back set in the truck with an extra birf for trail magic when needed.
PabloCruise said:
Kind of a silly question, but can you just remove a broken lockout and replace by simply undoing the nuts at the hub? Or do I need to take apart the lockout mechanism as well?
Thanks!
The actuation cap needs to come off, the bolt/washer or snap ring needs to come off the end of the axle, and the six nuts retaining the body of the lockout to the hub need to be removed, then the lockout can be slid off the studs/axle stub.
:beer:
:beer:
That what I needed mang - Thanks!
I forgot about the snap ring.
:beer: back atcha
