Hub to rotor bolts
That cone washer/nut torque seems a bit high - checking and will post if it is high.
DougM
Wow, my FSM says 26 ft-lbs. I recall when I assembled them it seemed a little excessive - perhaps this is why some are snapping these studs off. Go with the FSM.
DougM
26 lb-ft is correct. Remember those studs are hardened and so are the nuts and washers. If I had to substitute a "standard" nut I would back off on the torque a bit and get the correct nut comming.
Cruiserdrew said:
...I also use a Craftsman 2 1/8, but Dan was going to get me a real Toyota one...
Aside from it being the "real thing" is there an advantage to getting the Toyota one? I don't have one yet -- so it's either off to sears or add another thing to the C-Dan list.
Aside from it being a "factory special service tool" it has a 1/2 inch drive as opposed to a 3/4 inch drive like most sockets that big and the walls are the proper thickness.
D-
Originally posted by Arleaux
Sorry about all the questions, but the FSM I ordered from the Lexus dealership (2 wks ago) has not arrived.
How much did you pay for your FSM? I went to Lexus dealer parts department today but they were closed.
What is the acceptable preload on front bearing? I'm using a Haynes manual but it is not listed in there.
Oh yeah, Snap on sells 54MM socket for under $20 bucks.
My suggestion would be that you get the LC FSM (from C-Dan) and order just the LX EWD.
Mechanically speaking, I don't think there's enough difference to warrant getting the LX FSM. Wiring is different enough to warrant the othe guide.
I have the 97 LC FSM and EWD and use them for my LXs.
Doug,
I may have to do just that. Order the LC FSM from Cdan and EWD from Lexus. As I was driving down to the dealer, I was thinking that there was not much of a different as far as mechanical between LX and LC.
I will give Cdan a call on Monday.
$118 for the Lexus FSM
[/QUOTE]What is the acceptable preload on front bearing? I'm using a Haynes manual but it is not listed in there.[/QUOTE]
See Cruiserdans post above for preload instructions
