How often do you change these fluids?
So Cal
Power steering?
Brake fluid?
The manual says to inspect every 30k miles, but when is a good time to change?
Thanks
I recently changed my PS fluid out for Amsoil ATF and it will be a long long time before I change it again. In fact, I had all of the transmission fluid changed over to Amsoil ATF with a BG machine at the same time and I'm seriously thinking it's good for 100k so I might change the PS fluid again at that time (if I live that long!).
Brake fluid on the other hand is hygroscopic and, therefore, does absorb moisture over time. Moisture in your brake lines can't be a good thing. Many people go years without changing their brake fluid but I normally change mine every 2 to 3 years.
Brake fluid, every three years or 60,000 miles whatever comes first. BTW check what 'DOT' rating you should have, DOT 4 is not always OK for DOT 3 systems ect due to additional chemicals that may or may not be compatible with yoyur system. If you go to silicone brake fluid the pedal is a little 'wooden' when the fluid is cold but improves as it warms up however you will need to super clean the syytem to get rid of the old fluid and may need to change certain rubber components
regards
Dave
I use a vacuum tool to suck the Power Steering Fluid (I use M1 ATF instead) out of the reservoir and then fill it fresh every time I change my oil. I do my brake fluid flush yearly if not more due to other brake system procedures like replacing my pads, rotors or calipers. HTH. :cheers:
I'm making a list and checking it twice...of the fluid change intervals.
Engine oil = Every 5k miles
Transmission, differentials, transfer case, coolant = Every 30k miles
Brake fluid = Every 60k miles
Power steering fluid = Every 100k miles
It doesn't always work out perfectly, but I'll err on the side of an early change.
