What is pictures is called the slip joint or spline joint. Just coat the splines with enogh to cover them. Anymore than that will just be Squished out of where it is needed anyway. It does not take a huge amount.
I generally pump grease into yokes/U-joints until you start to see grease moving out of the rotating parts. It's able to escape and let you know it's plenty full.
The slip joint is another matter. Think of it as basically a hydraulic jack that is a little leaky. Pump it full and you'll put pressure on the yokes and whatever they're attached to, the axle and transfer case. You'll think you've developed a major problem from the bad vibes or even noise. Unscrew the zerk to relieve the pressure. Don't pump past the point when you first see the shafts start to move apart to avoid that.
Never dealt with a DC yoke on a LC myself. It's something of a cross between the two, so might be best for someone else to add specific advice on that
More than "not enough" but just less then "too much". There has never been a quantitative amount that I've ever read/seen. I usually give it a squirt every other oil change because I'm always concerned about over doing it due to the potential of hydro locking it.
One option is to first coat the splines of the yolk and the shaft (down in the hole) with a 60% Moly Paste (Loctite) or 60% Moly grease (Honda makes one for shaft driven motorcycle splines). Then put some Valvoline Palladium grease (3% Moly) in the hole and on the splines. Remove the zerk, put the yolk into the hole, work it up and down to spread the grease around, any excess grease will come out the zerk hole, put the zerk back in.
Grease the u-joints until the grease starts coming out of all four caps. Alot of times a grease passage will be plugged and starve a cap of grease, thus the needle bearings in that cap will fail. So verify it is coming put of all the caps then clean up the excess so you don't have it all over the bottom of your rig. With the splines just coat them with grease and get on down the road.
If the yoke zerk spits grease or is hard to pump as Greentruck stated you are asking for problems.
My solution is to pull the zerk and spray some PB Blaster, WD40, or brake cleaner into the yoke with the normally supplied red tube.
Get it deep inside to break down caked crud.
Drive around, reinstall zerk, regrease and just plain monitor.
I do grease twice per month and yes the whole drivetrain loves fresh grease
In your case a fresh cleaning be liberal and give her a healthy coating, wipe off excess and go!
