HOW MUCH FOR THAT PART?!
Indianapolis
So I received a 1997 Toyota Land
Cruiser for my graduation gift. It’s been in our family since new and it’s been well used. It needs some work and I want to start by fixing the drivers door lock, it does not work through the power lock switch but will work with the key all the other locks work just fine. This means it’s the door actuator right? Well I called up Toyota to get the part because Autozone doesn’t carry it nor does rockauto. You know what the dealer says to me?! 479.99! For a door actuator! I thought he meant Pesos! I asked him to switch to the US dollar please! So anyway I have 2 questions, is it the door actuator? If so where can I get one for cheaper?
Info about my truck
1997 Toyota Land Cruiser with factory remote entry although we have since lost the remotes probably 10 years ago.
Thank you for Your help!
Open the door panel and make sure there is power at the lock when you activate it. Use a meter or 12v test lamp. I have a '92, and I've never dug into the lock other than to change worn lock pins, but troubleshooting electro-mechanical stuff is pretty routine. I'd be surprised if the lock solinoid was actually bad. More likely it's dirty and cleaning could resolve your problem . Worst case, after you try cleaning it you can look for a used one. Try sor.com. I've been using them a bit lately for a cylinder head gasket overhaul. Good luck, Paul
Also, use some of the sources on here for parts.
Used:
@slow95z
@arcteryx
New:
Toyota Parts | Toyota Online Parts | Genuine Toyota Parts | Toyota Parts Online
LAND CRUISER FJ80,FZJ80 FZJ80L-GNPEKA | Toyota | Genuine Parts Catalogs | PartSouq Auto Parts Around the World
You will find that each Toyota dealership makes up their OWN MSRP pricing and then their own discount schedule. I have had parts range 200% for the SAME part within a 50 mile radius of 5 different Toyota dealerships. That's when I found McGeorge online.
If you don;t already have one, get a job to support your Land Cruiser addiction. We ALL have it!
And....the OFFICIAL 'Mud welcome: :flipoff2::flipoff2::flipoff2:
Also look for the FREE FSM (Factory Service Manual). Do a search for "for a hell or a price" to find the link. You'll need the 96 manual.
I replaced just the motors in all 4 doors on mine and they now work great. Also was able to get aftermarket key fobs that were easy to program. Probably spent $40 or so for the motors and the fobs (ie. it was cheap). Search the forums for info, that's what I did and I found way more than I expected like the lead on the cheap motors that are pretty easy to install.
Another Option
So I read through this thread and the full 13 page thread in the 100 section. Buried within the 100 section thread was a post by "ubiquityman" who had success by taking apart the small motor and cleaning it. Since I didn't have a new motor on hand and I'm not even sure which one to order for the 80 series and I'm not as talented as "cartercd" to weld a nail to the end of a motor shaft, I figured I would give it a shot.
It seems to have worked. After 2 years of classic symtoms, the lock is working great now. It appears that grease and crud had collected itself onto the commutators and brushes of the armature. With a little WD40, paper towel and a small screw driver I was able to clean it up substantially. Here are some before and after pictures to help you if you want to try it yourself. Note all the grease/crud on the paper towel in the background. I'm definitely gonna go this route on the other locks as they have issues. If I find one where the brushes are too wore out, then I'll try ordering another motor. I hope this info helps...
Power Door Lock Problem - Driver Door
Found quote on page two of the thread. May consider replacing/cleaning the small electric motor.
Wow! Thanks everyone for the response. I have a basic mechanical inclination so I think I can get in there and figure this out, up until now I’ve only owned fords and they are all built pretty much the same so I ASSUMED it’s a door lock acuator in there that’s broken. But i didn’t think that perhaps my LC is built better. So my first stop should be to clean it then? Let me know what else you’d like to know about LC. Thanks for the warm welcome I can’t wait to wrench on this thing!
We like pictures of Landcruisers. In fact, we demand them......
